Results 1 to 8 of 8
    May 2015
    Hi ka tsikot! Tinutulungan ko kasi yung pinsan ko sa sasakyan nila Hyundai Accent Gas 2014. Nagleleak yung puno ng tubo from break fluid reservoir. Sabi ng pinsan kong isa na mechanic, need lang ng repair kit for that problem. Saan kaya nakakabili? Nagcheck na ako sa pasay kay Good gear at sa iba pang shops. Wala daw eh, brake master assembly binibigay sa akin. Baka may alam pa kayong mabibilhan?
    Jul 2013
    Kung wala sa Pasay, try Banawe (although hindi ako nagagawi dun).
    Kung konti lang difference ng repair kit at assembly, consider buying the assembly.
    Aug 2017
    Quote Originally Posted by Lew_Alcindor View Post
    Agreed 101%... Your life depends on it, and other people's lives.
    Try Banawe... Fronte, Lucky Two Motors, Seiring.
    fix em brakes now.
    Apr 2009
    Quote Originally Posted by johann123 View Post
    if your car is still under warranty, bring it to the casa and have the whole brake master assembly replaced (also with the Hydrovac if deemed necessary). If it is out of warranty, I still go for replacing the whole brakemaster replaced with OEM. Why? It will be guaranteed problem-free and save you time, money and headache..
    if the leak is around the pushrod/plunger, then repair kit may be the answer. or, if you do not want to guess, a brand new brake master assembly.
    but if the leak is at the base of the metal tubings that lead down to the brakes, the first question to ask is, "is it the brake master, or is just the tubing?
    if the tubing, and it usually is, getting a replacement from the store might be the easy answer. or, one can have one made, at some auto parts stores.
    if the brake master, i suppose replacement is the only option. i know of no repair kits for that part of the assembly.
    May 2015
    Yung tubings po ang may leak when applying the pressure. Sabi kasi ng pinsan ko nagbabawas daw ng break fluid. Then we saw something sa tubing tumatagas na rin siya sa semento. Gumagapang na yung leak. Pero mas malakas ang tagas kapag applying ng pressure/brake. Yung puno po ng tubing. Tightened naman po.
    3.3k for Assembly, and sabi ng pinsan ko di daw lalagpas ng 1k ang repair kit.
    Jul 2013
    Kung tubing (kung saan nakakabit ang tube sa assembly) ang may tagas, hindi repair kit ang solusyon jan.
    Baka kelangan lang i-flare uli ang tube para fit na fit sa assembly.
    have the tubing re-flared (kung puede pa), or have it replaced.
    it's easier than one might think.
    all you have to do, is watch and pay the guy who will do it.
    after it is fixed, you may then participate in the "tapak... bitaw..." bleeding process.
Any know where to buy brake master repair kit?
