Results 1 to 8 of 8
- May 2015
- 146
June 7th, 2018 11:35 AM #1Hi ka tsikot! Tinutulungan ko kasi yung pinsan ko sa sasakyan nila Hyundai Accent Gas 2014. Nagleleak yung puno ng tubo from break fluid reservoir. Sabi ng pinsan kong isa na mechanic, need lang ng repair kit for that problem. Saan kaya nakakabili? Nagcheck na ako sa pasay kay Good gear at sa iba pang shops. Wala daw eh, brake master assembly binibigay sa akin. Baka may alam pa kayong mabibilhan?
- Jul 2013
- 2,450
June 7th, 2018 11:57 AM #2Kung wala sa Pasay, try Banawe (although hindi ako nagagawi dun).
Kung konti lang difference ng repair kit at assembly, consider buying the assembly.
- Apr 2009
- 429
June 7th, 2018 06:38 PM #3if your car is still under warranty, bring it to the casa and have the whole brake master assembly replaced (also with the Hydrovac if deemed necessary). If it is out of warranty, I still go for replacing the whole brakemaster replaced with OEM. Why? It will be guaranteed problem-free and save you time, money and headache..
- 52,684
June 7th, 2018 11:50 PM #4if the leak is around the pushrod/plunger, then repair kit may be the answer. or, if you do not want to guess, a brand new brake master assembly.
but if the leak is at the base of the metal tubings that lead down to the brakes, the first question to ask is, "is it the brake master, or is just the tubing?
if the tubing, and it usually is, getting a replacement from the store might be the easy answer. or, one can have one made, at some auto parts stores.
if the brake master, i suppose replacement is the only option. i know of no repair kits for that part of the assembly.Last edited by dr. d; June 7th, 2018 at 11:56 PM.
- May 2015
- 146
June 8th, 2018 01:08 AM #5Yung tubings po ang may leak when applying the pressure. Sabi kasi ng pinsan ko nagbabawas daw ng break fluid. Then we saw something sa tubing tumatagas na rin siya sa semento. Gumagapang na yung leak. Pero mas malakas ang tagas kapag applying ng pressure/brake. Yung puno po ng tubing. Tightened naman po.
3.3k for Assembly, and sabi ng pinsan ko di daw lalagpas ng 1k ang repair kit.
- Aug 2017
- 319
June 8th, 2018 10:09 AM #6
- Jul 2013
- 2,450
June 8th, 2018 10:24 AM #7
- 52,684
June 8th, 2018 10:47 AM #8
Ang tagal na ibinalita yang ban. Tapos warning pa ang ginawa first few days. Yung mga nahuli pa...
E-bike / E-trike ban details released by MMDA
