help pls d ko alam kung ano to
i have a lancer 89 bkt me ganito??
normal po b ung bakal na un para sa likod na suspension??
what connects between the two rear wheels is the dead axle. it does not help to propel the car, it is just there for wheel geometry and as a means to connect the other suspension components to the chassis. the other component connected between the body of the car and the axle is the anti sway bar. it is there to prevent your car from dancingand swaying after a turn or after hitting uneven surface of the road
Look under a Montero Sport and you will see the same thing. Only difference is the Montero has a rear differential (aka 'bungo') because it has rear wheel drive.
This type of suspension is inexpensive to produce and maintain. Also allows for a bigger trunk room than if you had a fully independent control arm set up back there.
Sentras use a similar type of suspension but with some detail variations.
Mas durable yan vs independent suspension but mas matagtag din nga lang.![]()
Fasten your seatbelt! Or else...Driven To Thrill!
thank you guys so it means its normal?? tama lng un kac pagnatingin ako sa ibang car n kapareho ko d ko nakikita un ehhh... big help
