Look under a Montero Sport and you will see the same thing. Only difference is the Montero has a rear differential (aka 'bungo') because it has rear wheel drive.
This type of suspension is inexpensive to produce and maintain. Also allows for a bigger trunk room than if you had a fully independent control arm set up back there.
Sentras use a similar type of suspension but with some detail variations.
