Results 1 to 10 of 11
- Oct 2004
- 132
December 4th, 2004 10:56 AM #1Curious and tanong ko na rin...
Is it required/mandatory na magpa-align (wheel alignment for example) after changing suspension parts like shox, springs and etc.???
I'm planning to do my suspension and was wondering what to do next? Any input from you guys?
December 4th, 2004 11:27 AM #2
kung suspension works gagawin mo,you dont need an alignment,but,you need a camber..because of the different suspension,the wheels may not be at a correct angle to ground which may lead to uneven wear in either outer/inner thread of the tire..
a camber job is much expensive than a alignment,but, a camber job mostly include wheel alignment..
you only need a wheel alignment if you repair the steering rack or change tie rod/tie rod ends..
once you replace it,its better to go to a reputable shop to have it checked..it free naman..
be sure than soooorrrry..hope i'd helped
- Oct 2004
- 132
December 4th, 2004 02:09 PM #4Ahh...ok. Next stop camber alignment.
alwayz_yummy -> ur the man!..
BlueBimmer -> wat can i say? ur still a man dude! :D
tnx
December 5th, 2004 08:04 PM #5
thanx po sir!felt good to help..
kasi experience ko ito sa van ko..aquired sa subic...una panaman sira ung underchasis and streeing rack.. at sa span ng 4 years i have changed 2 sets of 30x9.5 lt due to incorrect alignment/camber..
pagpalit ko ng gulong ngayon,ipapacamber ko kasi general suspension works have been done..
welcome!
December 22nd, 2004 12:13 PM #6
nyek! dapat pala pina camber ko na pagpalit ng mga tie rod
ngayon pag nagdadrive ako pumapaling sa kanan pag binitawan ang manibela.
December 22nd, 2004 12:33 PM #7
better get that done ASAP, you wouldn't want to have uneven tire wear. San area ka ba? :D
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Oct 2004
- 132
December 28th, 2004 10:38 AM #9Hanep si speedyfix sa mga posted replies.. hataw!..
BTW, anu services offered nyo (specialties) sa shop nyo sir speedy? Lapit lang kc ko sa inyo kung d ako nagkakamali(we're near camp crame).
December 30th, 2004 02:34 AM #10
speaking of alignment...I just my shaft kit bolts changed. before I got the job done, my tbars were cranked up to provide more lift. But then after changing the shaft kit bolt today, my tbars dropped a bit. Will there come a point wherein once you lift your vehicle ,via t-bars, the camber alignment can't be done correctly?
Gamet ko cone filter kapag ba malakas Yung higop Ng hangin servo motor na tlaga sir
LANCER Itlog (93-96) Owners - Please Post Here!
