Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Dec 2010
    i have a ford fiesta... 2.5k km odo.
    if the steering wheel is straight... may konting kabig to the left. to go straight... the steering should be about 3-4 degrees to the right.
    alignment problem ba to? baka nalubak.
    tire pressure is ok. didnt modify anything. stock mags/tires and all. di daw kasama sa warranty alignment and theres a 900 consultation fee (?) sa casa. so im thinking of bringing it sa goodyear servitek.
    any ideas?
    Quote Originally Posted by antikryst View Post
    any ideas?
    Wheel alignment nga yan IMO sir. Servitek na nga lang. Pero ang bulis naman niyang nag-mis aligned. Yung Avanza ko dati at advie, parang 3 years bago nagpa-align.
    Dec 2010
    feeling ko nalubak. the car i replaced parang once every 5 years lang pa align. it was a lancer glxi... 18 years before i replaced it haha.
    Ganyan din yung jazz ko. Nung bago pa lang yun pag diretso ang manibela pumupunta sa kaliwa. wala akong alam sa oto non kaya hinayaan ko na lang. pwede mo ibalik siguro sa casa yan sa PMS mo.
    Feb 2009
    the problem is in the clocking of the steering wheel. the steering angles might be correct but the over the center adjustment is off. but then again it is a ford. have the tie rods adjusted to the 12'oclock steering wheel while the front tires are straight ahead. this should be taken care of by the dealership and it usually takes less than 20 minutes to reclock the steering wheel
    Jul 2010
    Alignment lang yan bro, sana walang bayad.
    Ganian ang strada ko ngayon, pina-service ng erpat ko sa GNS Auto Dagupan City at naging ganian. Di ko na mabalik kasi nawala resibo.
    Saan kaya maganda magpaalign and magkano kaya? I have no idea kasi. TIA!
    Dec 2010
    do you think its more of a clocking than alignment? kasi if its clocking i can live with it for now. just worried ill ruin my semi new tires this early due to alignment problems.
    kung clocking lang i can wait for my next PMS (6 months) which is about 3 months away.
    is there a way to check if its just clocking or alignment?
    Mar 2011
    ang tingin ko dyan napakaaga naman para magkaproblema ka ng ganyan. almost brand new yan wheels mo dapat di ka pa magkaproblema ng ganya. kng ang pagcorrect nyan sa casa ay may charge malamang sa hindi sinadyan nila yan para bumalik ka sa kanila at madagdagan ang kita nila. bro in law ko bago innova G nya ganyan din one month palang. terrible na defect yan. ang isuzu crosswind xto 2001 ko nabili ko 2 years ago. pagkabili pinaalign ko wheels hanggang ngayon no problem pa.
    Dec 2010
    went to servitek... wala pa sila specs to align the fiesta. hassle. hintay na lang siguro 6 month pms... which will be in 3 months pa.
    Feb 2009
    if the car is not pulling, not leading and not drifting and tracking straight on a straight road, there shouldn't be problem with the alignment. if you are constantly correcting the direction or have to hold it from leading to one side, there is a problem. the camber and/or the caster could be set wrong. the road crown has to be considered when adjusting these two angles aside from the thrust angle
    Dec 2010
    i dont feel that im constantly correcting or holding the steering wheel on one side to go straight... if it is... its super negligible. so this is ok?
    but to go straight... the steering wheel is slightly to the right and not straight. if i just let go of the steering wheel i feel that it still goes straight (if not its also negligible) but the steering goes a bit to the right. on some attempts to go straight while letting go of the wheel... it sometimes veers super slightly to the left.
    really not sure on what this problem is as i never changed anything on the suspension, wheels, or tires.
    Feb 2009
    was the car assembled in the philippines? ave the alignment angles checked. the most common causes for your symptoms are improperly set camber or caster. for left hand drive cars, it is set slightly more positive caster on the right and/or slightly more positive camber on the left to offset the inclination of the road crown. so far, your symptoms are more of steering wheel over center adjustment. what needs to be done is to shorten the right hand tie rod and lengthen the left tie rod the same amount to center your steering wheel.
    Dec 2010
    its assembled in thailand from what i know. theres even a possibility that it was like this when i got it... baka di ko lang napansin before.
    went through the 1 month or 1k odo check 2 months ago and i believe they checked tire wear and alignment... which was ok'd
    if its just steering wheel centering then thats ok for me... for now.
    try mo kaya sa kalikot sa evangelista, makati. nagpa-allign ako don ng galant ko, 1 year and 7 months ago, hangang ngayon, ok pa.
    ewan lang kung kaya na nila ang fiesta. ano ba yan, que bago2X pa lang ng unit mo may problema na, and the casa can't fix it ba?
    Dec 2010
    Quote Originally Posted by galant E SS View Post
    casa can fix it for sure pero mahal. if its not that important then ill wait for my PMS. kung steering wheel centering lang then it can wait.
    Sayang naman, kahit walang specs kasi basta may laser guidance ma-align agad yan. 6 months kasi is too long IMO. Baka malaki na negatibong epekto niyan sa gulong at ibang suspension parts.
    Apr 2011
    any ideas?
    I don't think alignment yan sir. Mashado maaga for it. Try rotating the wheels. :D pag palitin mo lang yung left and right front tyre. pag may kabig pa rin, try rotating the rear and front tyres.
    May 2011
    Any update on this Boss? My cousin's fiesta is experiencing the same issue. He asked me to test it and I have to constantly hold on the steering while driving kasi may slight "kabig" on the left... Di kaya factory defect siya?
    Apr 2011
    ts...free lang yan sa dealership mo for alignment..ibalik mo na agad yan at para mapa ayos na baka un iba pa ang masira like suspension and alike.
alignment problem on new car
