Results 31 to 40 of 44
January 6th, 2004 02:54 AM #31Originally posted by carloi
Just for the record. Smaller diameter steering wheels are harder to turn because you have a shorter lever arm. To check, turn on your engine, and turn your steering wheel. Now, remove steering wheel and try turning the tires using only the center thing with your fingers. Kaya ba?with matching Physics reference
di ba merong specific hub adapter ang mga MOMO? Ungas, yun ba yung sinasabi mong adapter na problema ni yamyam?
January 6th, 2004 08:42 AM #32
Karding::: Yep, kahit na may specific adapter kit for the specified vehicle, minsan sablay yung sukat ng gatla para mag auto release yung turn signal lever. Napansin ko itong difference lalo na sa mga Taiwan made adapter kits. A mere 2mm difference will have you switching the lever back to its normal position. Minsan dinadaya ng Banawe boys by adding grease. Which will add more burden.
January 6th, 2004 09:20 AM #34
Hindi kung san maganda magpakabit, ang dapat hanapin mo kung san nagbebenta ng orig na MOMO adapter kit. Kahit ikaw kayang kaya mo na gawin yun sa sariling garahe nyo.
January 6th, 2004 03:53 PM #36
Lahat ng nagbebenta ng MOMO merong adapter kit. for sure orig sa Autosport Megamall and sa Perfect Circle in Banawe. I got my club4 for about P8500+. Sa Autosport P9000+ ata.
Mahirap pong magpalit ng orig na manibela pag virgin pa (first time tatanggalin).
Dapat meron kang steering wheel puller. pero banawe boys, yakang yaka gawin yan.
Problem ko ngayon is hindi ko matanggal yung jack nung airbag module ko.
January 6th, 2004 04:41 PM #37
PK, bakit hindi mo maalis?
Even with the battery off?
Paturo ka sa Mitsu section ng 4x4wire.com . Dun ako kumukuha ng DIY tips.
January 6th, 2004 05:54 PM #38
Otep, hindi kasi pamilyar sa aking paningin yung jack na nakakabit sa explosive. Binasa ko sa service manuals pero walang detailed pic on the removal of the said jack.
Pero tama ka. Airbags can cause injury. Dun nga sa manual, dapat ipitin sa loob ng 4 used tires yung airbag module bago paputukin!
Takut ako!
January 6th, 2004 05:58 PM #39
.....isa pa, bibili muna ako ng steering wheel puller. Naka seal pa yung nut ng manibela. Like i mentioned earlier, medyo matigas hilahin yung wheel from the spline.
January 6th, 2004 06:44 PM #40
Di kaya mas lalo ka mapamahal sa puller? Try to secure a metal bar across the OE steering wheel (which should be thick and longer) then hit both sides. This will also serve as protection just incase the airbag sets off if you forgot to pull out the terminals.
up for suzuki
Let's keep our Chapter Alive! ATO NI Mindanaoans!
