Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Sep 2011
    I have a Nissan Exalta STA car. Napasudden break ako kanina and then nag on yung ABS Light. Nung ipapacheck ko, namatay naman. Tapos from Pandacan to Evangelista Makati, di siya nag on. Nung pauwi ako nag on ulit. Ano kayang problema? And san ba pwedeng magpacheck up which is free? and yung pwede magpaquotation kung anong problema.
    Feb 2009
    Quote Originally Posted by iamjcesteban View Post
    first, check if your tires' circumference are within one inch of each other. check if the tires' age (coefficient of friction-tire traction) is no older than five years old. check if your wheel speed sensor trigger wheels are free of iron particles and that the wiring are neither frayed nor loose contact.
    Oct 2011
    If problem still persist, dalhin na lang at your nearest casa.
    chance is you won't get a free abs diagnostic, masyado mahal scanner for abs...
    Sep 2011
    Do you know shops where I can have my ABS sensors be cleaned? That will be my last resort before going to Casa. Already asked Nissan UN for the abs diagnostic. It costs 2,500. But they will do it for a maximum of 3 days.
    Feb 2009
    doesn't the philippines have competent technicians? this operation is a routine operation and an almost everyday occurence at the dealerships.
    3 days masyadong matagal yan for diagnostics. mahal din yata yung 2,500 fair lang siguro mga 1,500 anyway casa yan. hanap ka na lang sa mga independent shops na may abs capable scanners. kung makati area ka pwede natin try our scanner kung mabasa ang abs mo.
    Sep 2011
    Quote Originally Posted by t2erns View Post
    Near makati lang ako sir, magkano charge mo and saan po kayo? Do you know how to read codes kung mabasa man yung ABS ko? Thanks sir.
    our shop is charging 1,500 for diagnostic scan.
    automakati 1403 p. ocampo st, san antonio, makati city
    Jan 2009
    ganyan din nangyari sa 2nd gen na vios namin. after magpalit ng gulong nakailaw na yung ABS. pinabayaan ko na lang.
    ^ not such a good idea?
    ABS light means ABS is OFF
    Oct 2011
    Quote Originally Posted by frequenzy View Post
    pinalitan lang ang guling umilaw na abs? bakit nagkaganito?
    Jan 2009
    Quote Originally Posted by mda View Post
    iniisip na lang namin na dati yung mga sasakyan wala naman ABS. tsaka mga lowend ata wala rin ABS
    nagpa align kasi after palitan yung gulong. tinamaan cguro yung sensor.
    Sep 2011
    wala bang discount sir? hehehe. machecheck nadin yung ibang problems if ever pag nag diagnostic scan tayo di ba? and if we found out na may problem nga abs, can we remove the abs instead and conventional breaking na lang ang gagamitin ko? how much ang charge sa removal of abs?
    Sep 2011
    I even asked sa casa, okay lang naman daw na i-drive kasi even walang abs, andun pa din yung conventional breaking. just wanna ask, so hanggang ngayon hinayaan niyo lang na nakaon yung ABS light? what i did was to removed the bulb ng abs sa dash para di na umilaw. nakakailang kasi, but i have plans na ipatanggal yung abs. 500 daw charge sa evangelista. I'm looking for shops na mas mura ang charge. and baka ipa-diagnose ko na din if ever mang kasama na dun lahat.
    Oct 2011
    yes, walang kinalaman sa hydraulic braking system ung abs.
    Sep 2011
    so what advice can you give sir, patanggal ko na lang yung buong abs module or hayaan ko na lang na ganun siya?
    sa akin, sayang yung abs mo kung ipapatangal mo.
    try mo i pa check... dahil minsan, yung warning light indicators may show some deeper problems.
    Jan 2009
    If you intend to disable the ABS, pulling the ABS fuse would've sufficed. But then, who in their right mind would want to do that?
    ABS allows you to steer the vehicle out of harm's way even if you have both feet on the brake pedal. It's a safety feature that you hope you won't have to use. But if the situation asks for it, your chances of preventing or reducing the severity of an accident is greatly increased.
    So have it fixed. It may or may not cost a lot, but you can't put a price tag on the life or limb it can potentially save.
    napaka importante nga nyang abs esp ngayon tag ulan and madulas ang daan
ABS Light on while driving
