Results 1 to 10 of 103
- 54,205
April 18th, 2025 11:53 AM #2
A digital storage oscilloscope is not a nice to have but a must have for a reputable technician. Similar to the medical field, a hospital must at least have an X ray machine. You can not advice or recommend to a patient what to do if you are limited on informational or diagnostic equipment.
April 18th, 2025 11:59 AM #3
April 18th, 2025 12:22 PM #4
The subject vehicle in question is a typical four channel ABS/traction controlled system that uses two wire sensors( per channel). You can set your DSO in auto mode(voltage for Y axis and time/frequency for X axis) and adjust either once you capture the waveform. There are tutorials on YouTube on the use of DSO. There are also tutorials from aeswave.com.
Better to buy the similar-era clone starex 4x4 (not sure lang if local or imported but original lhd...
Mitsubishi Philippines
