Results 1 to 9 of 9
March 18th, 2007 02:30 AM #1
considering pareho po silang bagong bili. i know it was a stupid idea pero nangyari na po eh. i need your help on how to arrange them. my ride is boxtype pajero. thanks guys
Tsikot Member Rank 3
- Oct 2006
- 1,069
March 18th, 2007 02:39 AM #2Whatever you wish to mount in front will always be right because its your ride
March 18th, 2007 10:29 AM #3
It doesn't matter because you will be rotating the tires regularly as part of maintenance.
Just make sure that the tires on each axle are a match. E.g. both front tires are similar, both rear tires are similar.
March 19th, 2007 09:09 AM #4
thanks guys. i was thinking kase of putting the AT tires infront because mabilis mag-wear ang front and since I rarely go offroad
BANNED BANNED BANNED
- 3,790
March 19th, 2007 09:24 AM #5I suggest AT sa front for road grip issue, MT sa rear for off-road traction naman.
You need not rotate, but you will need to buy a pair when it wears off. Make sure ipabalance mo ang mga gulong and maintain the right tire pressure all the time para maganda ang wear and tear nito. Sa front make sure na align and proper ang camber settings.
- Jun 2005
- 215
March 25th, 2007 10:34 PM #8
A/T - all terrain tires
M/T - mud terrain tires
These are designations for SUV/truck tires.
March 25th, 2007 11:58 PM #9
since you rarely go offroad, sa rear nalang m/t tires, sigurado namang mas mauunang mapudpod yung m/t kaysa a/t, next time puro a/t nalang gamitin mo
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
