Page 57 of 61 FirstFirst ... 747535455565758596061 LastLast
Results 1,121 to 1,140 of 3407
    Let me help you guys
    2014 Subaru Forester XT vs 2013 Subaru BRZ Comparison - YouTube
    No question on the handling capabilities of the BRZ as it is lighter and has better aero package. In terms of brute straight-line acceleration, the FXT can outsprint the BRZ mainly from its turbo engine. The BRZ and FXT share a similar engine base (FA20) but the FXT is turbocharged. The BRZ would have been a much better drive if it has the engine of the FXT.
    Below is a written review based on the same video.
    214 Subaru Forester XT vs 213 Subaru BRZ : Car Reviews
    Mar 2013
    Ayos. Casa really knows how to make moolah.
    I had the first checkup for my.mini cooper..change oil. Cost me 11k. Ouch.
    Sent from my SM-N950F using Tapatalk Pro
    Jan 2008
    Expansive check up..so much for da mini
    Jan 2010
    2015 OEM subaru forester head unit can this be updated? connecting via bluetooth the app icon is gray out? can only use the phone and music function, where can you get its system update if there is one available? tnx
    May 2018
    mga sirs, ask lang po ulit ako for dashcam recommendations for this unit.
    I prefer po sana yung nasa likod na lang ng rear view mirror para hindi ko na siya alisin.
    Ask ko na rin if sa car charger (cig lighter) ko ba siya ikakabit? haha.. sorry noob.
    Thanks po!
    Had my 5k PMS last June 2018. Now I'm getting texts from Subaru Greenhills that I'm due for a service again. When I clarified it, they texted me two different messages -- one is saying to disregard it while the other is saying they have a "service clinic" every 3 months.
    Is this normal for a Subaru?
    Oct 2018
    Quote Originally Posted by Capsaul View Post
    Hi Capsaul,
    Have you updated your head unit? In my latest forester mode it doesn't have app icon, sometimes bluetooth and telephone icon were grayed out. How did you fixed it?
    Oct 2017
    Guys need a little help here- I think my radiator has a crack. I see coolant splashed in the engine near the battery side of my 2011. Any suggestions on where/how much to go about repairs?
    Merry Christmas to all as well!
    Hi. Anyone have estimate of how much CVT fluid change is for 2013 2.0 Forester non-turbo? Looking to have it done ouside casa but the CVT fluid seems a bit expensive when outside shop quoted me.
    Quote Originally Posted by moipogi View Post
    It’s around 10k with a drain & refill method plus gear oil change at Fusion R. That’s fluids and labor.
    Call your nearest motech...
    Aug 2010
    Is 2019 Sport Model going to be available here?
    Quote Originally Posted by tcbi View Post
    Only two models will be released locally for the new Forester - base and Eyesight models.
    Mar 2004
    Hybrid to follow ...
    Mar 2018
    Priced competitively yan cguro yan 2019 Forester E-Boxer, kasi bawas ang excise tax nyan under TRAIN.
    Mar 2004
    Still expensive technology so might still be expensive ... Might perform better than an XT though ... instant torque ...
    Hi pips, do you think it's still ok to buy the current model given the discounts (180k I think) offered?
    when idling and ac off... is the radiator fan going on for a half a minute then off again(until it reaches a temp) then on again. it cycles...
    your symptom is of a not properly bled coolant... air pockets perhaps..
    Mar 2018
    *Injustice21
    This sounds right -- when last time na flush/napalitan coolant? Nag-eexpire din kasi ito, and kapag ganyan imbis na liquid most of the time nag-papalit na yan from vapor to liquid -- then eventualy parang tubig nalang sya hindi na effective yuh eth. or prop. glycol, unti unti na yan mauubos/sisingaw.
    Compare mo din difference ng coolant level ng reserve kapag malamig sa umaga and nasa operating temp. Dpat tumataas-baba, kapag operating-temp dpat mas mataas kesa yun level nya pag umaga at completely cool -- dpat higop-buga ginagawa ng radiator sa reserve to maintain pressure habang nagiiba temp and dito rin dpat na-eeliminate air pockets.
    Jun 2018
    Thanks Sirs Don900 and StockEngine. Will check these when I get home. I'll also have it checked at Fusion R since my brakes and spark plugs are due for replacement na rin.
Subaru Forester
