Page 265 of 341 FirstFirst ... 165215255261262263264265266267268269275315 ... LastLast
Results 2,641 to 2,650 of 3407
    Dec 2017
    #2641
    Tried uploading the pic of clock but it keeps on failing.
    Thanks ill try that when im back in manila. Still at the province.
    Sent from my SM-N950F using Tsikot Forums mobile app
    #2642
    Quote Originally Posted by marlowetd View Post
    There have been issues with uploading pics on tsikot.
    Sent from my SM-T705 using Tsikot Forums mobile app
    #2643
    Found an Owner Manual online. Re: clock 12/24 hr display.
    The clock can be set to 12-hour or 24-hour
    clock displays. Perform the following
    procedure to switch the display format.
    1. Place the ignition switch in the
    “LOCK”/“OFF” position.
    2. Press and hold the “−” button that is
    located near the clock display for approximately
    5 seconds. The clock display will
    then start to flash.
    3. While the clock display is flashing,
    press and hold the “+” button for approximately
    2 seconds. The clock format will
    then change.
    4. The clock display will continue to flash
    for approximately 3 seconds to inform you
    that the clock display has been changed.
    If you want to change the clock display
    again, press and hold the “+” button for
    approximately 2 seconds while the clock
    display is flashing.
    HTH
    Dec 2017
    #2644
    Quote Originally Posted by kinyo View Post
    HTH
    Thank you!!!
    Jun 2013
    #2645
    good day guys. may nakaexperience na ba dito sa inyo na yung Air inlet selector button ng AC ay namamatay kusa yun ilaw? dati kasi hindi ganun yun sa forester ko. tia
    Jan 2018
    #2646
    Quote Originally Posted by Piver View Post
    You mean yung air recirculator light?
    Automatic na kino-control sya ng auto to bring in fresh air into the cabin.
    If ayaw mo syang mag off, while your car is turned on and naka ilaw sya, press the air recirculator button twice. Then when parking your car, only turn off the AC switch and not the fan. Next time you start the car, it will remember to keep the setting you had before.
    Mar 2004
    #2647
    Some auto climate control turns air re-circulation on and off ... so you can opt to use the auto fan control but not the auto climate control and then set it to cool mode ... also there are European models that turn it off every 10-15 minutes ... try to check your manual how to keep it on all the time ...
    Dec 2017
    #2648
    Hi just wondering. Can you guys recommend a storage box that i can keep in the car that can safely store electronic stuff or those that can be damage with excessive heat?
    Planning to store headphones or valuables just for the car for emergency purposes.
    Thanks!
    Jun 2012
    #2649
    Thanks!
    You can keep the headphones and other gadgets in their original hard case and keep them in the glove box or the center console box or on the floor. The car's inside temperature should not be higher than inside a container van where the gadgets were kept for weeks during transshipment and storage at the ports.
    Thanks!
    if you park under the sun, the car plastics are built to withstand 65C,
    some gadgets will easily degrade at that temperature. under my drivers seat there is an area i can fit my bose headphones. but i would never leave it there.
Subaru Forester
