Page 10 of 16 FirstFirst ... 67891011121314 ... LastLast
Results 91 to 100 of 159
    Jan 2018
    #91
    Im considering a 2010 WRX hatch. Anything I should look out for?
    Jan 2018
    #92
    Quote Originally Posted by 4A92 View Post
    Check for leaks from the engine and shocks. The oil seals would have worn out by this time if they have not yet been replaced.
    Check for boost leaks and for any knocking or pinging during hard acceleration.
    Check that the aircon is still blowing cold air. Also check the condition of the cabin filter. Ask if the evaporator has ever been replaced.
    Ask to see the maintenance stamp book if it was serviced in the casa.
    Check the level and quality of all fluids: oil, coolant, brakes, power steering, transmission. Ask when these were last drained and replaced. Not just topped off.
    Jan 2018
    #93
    Wow that’s comprehensive! Any particular known issues plaguing WRXs? I’m a total noob on Subies coming from a Mitsu family.
    #94
    Unless the WRX you are looking at was raced at the track for extended periods or modded heavily, the maintenance checks listed by SpinCycle is common for a used car with a turbo.
    Jan 2018
    #95
    Sounds good. Thanks!
    Jan 2018
    #96
    Nothing really stands out as a major issue. But if the car’s been modified, you need to ask the mod list and check for issues related to those mods.
    Oh and check the belts and water pump as well.
    Feb 2019
    #97
    I'm planning to get a wrx 2014 cvt with 24k mileage. Any feeback on subaru's cvt? Ive heard issues with it.
    #98
    Quote Originally Posted by Adrianf13 View Post
    Just follow manufacturer's recommendation on periodic CVT fluid change....every 30-40k kms depending on use/abuse....Baby it if you're keeping it long term.Common Subaru problems
    #99
    Subaru turbo engines have proven to be reliable but if buying used, just make sure you get one with no problems with its turbocharger.
    Ask the owner for a detailed maintenance history.
    Jul 2015
    #100
    Just had 2900km from my last fluid change, oil change again when it reaches 3k...earlier than usual
