Results 51 to 60 of 125
- Jan 2008
- 4,726
July 5th, 2021 11:54 AM #51
July 5th, 2021 12:20 PM #52
If wiper does not wipe smoothly when using water ... then wiper must be changed or windshield is dirty ... usually it's the wiper ...
- Feb 2013
- 910
July 5th, 2021 08:32 PM #53So no real advantage of using specific wiper washer liquids?
I forgot to mention that yes the casa does refill the wiper washer during pms. I meant it's the first I will do it outside the casa.
- 52,763
July 5th, 2021 08:34 PM #54
- Feb 2013
- 910
August 2nd, 2021 07:19 PM #55I refilled my windshield washer liquid tank with 2 x 2000mL Microtext fluid and I'm surprised it's still not full! If the manual does not indicate tank capacity for this liquid, how will I know?
- Jan 2008
- 4,726
August 2nd, 2021 08:12 PM #56
- Feb 2013
- 910
October 5th, 2021 02:37 PM #57Finally, I will have my car serviced in Fusion R tomorrow. However, the attendant is asking me if I want to have the "thermostat" of my car changed as well (for the cooling system and is located under the water pump). She's saying that they usually recommend doing this after 40K Km. Their quotes are:
Thermostat - 1,700
Coolant/distilled - 900
Labor - 2,500
So the coolant is partnered with the thermostat. In the previous pages of this thread, I decided to hold off replacing the coolant. So I'm not sure if the thermostat really needs to be changed. Thoughts?
October 5th, 2021 03:10 PM #58
Replacing the thermostat means replacing the coolant as well. Do this in one go.
- Feb 2013
- 910
October 5th, 2021 03:25 PM #59
- Jan 2008
- 4,726
October 5th, 2021 03:37 PM #60not sure.. but based on my previous coolant changes, at 40k kms, it still clean.. this is for my kia picanto using the green coolant same with my mitsubishi adventure at 100k kms.. coolant still clean.. no rust or any noticeable corrosion
even our toyota altis clocking at 200k kms! i changed its coolant hoses as part of preventive maintenance eh.. nagulat ako, no rust or any corrosion or build-up sa loob..
is the water pump can be easily replaced? some cars need water pump replacement as part of the timing belt maintenance.. to avoid nga yung masira ang water pump with the new timing belt..
If Mitsu prices this above 1.4M then buyers will flock to either the Corolla Cross hybrid, the...
Mitsubishi Xforce
