Results 31 to 40 of 72
February 2nd, 2023 09:52 AM #31
Mukhang Kelangan na palitan. For my vehicles, parang Di ko maisip to keep it running with tires used for over 40k km.
My XT has logged around 70k km and I am now on my 3rd set. Most people don’t appreciate fully the value of tires - these things are the only part of your car that comes in contact with pavement.
February 2nd, 2023 01:02 PM #32
Those need to be replaced already
60k on one set of car tires is pretty high. I did 50k on my last set.
- Sep 2021
- 903
February 2nd, 2023 01:51 PM #33Even if there are no alignment & camber issues, IMHO, a (little) wear on the outside of the tire is normal, because of cornering forces when the vehicle turns. That’s why its important to rotate their positions in accord with the schedule in the manual.
Parang pantay naman ang wear. Pudpod nga lang na talaga and must be replaced.
You won’t be able to see the wear bar anymore because your tire is worn too smooth already.
On a new tire, follow the direction of the little arrow on your sidewall to the closest groove. Inside the groove, you will find a raised strip of rubber running across, but not high enough to bridge the groove (nakalubog pa rin sa kanal ng groove). When the tire tread wears down to the point that that little strip of rubber is level with the rest of the tread (it bridges the groove already), your tire needs to be replaced.
- Jan 2008
- 4,726
February 2nd, 2023 02:42 PM #34bokal na.. needs replacement na nyan.. from the looks eh matigas na din yung tire compound nyan kaya slippery na..
sulit na sulit na kung umabot ng 60k kms yan stock tires..
- Jul 2009
- 2,618
February 2nd, 2023 05:25 PM #35from mileage alone ang pinaka malayong natakbo ko on a set of 4 tires ay 54t kms. palitin na. technically kalbo na siya wala ka na kasi makakapang wear bars. pantay na.
- Feb 2013
- 927
February 2nd, 2023 06:37 PM #36Yeah, I understand. And I just realized that my last PMS with 2211 Works was Nov 2021 (at 44.5K Km). This is totally negligence on my part and I have no excuse part. I remembered back then that the 2211 Works tech that worked on my card said that my tires are still "ok" but they need to be replaced the next time I have my car serviced.
Regarding your wheel alignment question, no I never had them realigned. I'm reading that this can be the cause of uneven wear on the outside of the tire but is this the only problem that I need to fix? How long is in the interval for when I need a wheel alignment service done on my car's tires?
- Feb 2013
- 927
February 2nd, 2023 06:58 PM #37Ok, got it! Using that little arrow makes a lot more sense to me now.
As much as I want to use Otani though, parang mas gusto kong magstick sa strictly sa stock tire size which is 225/55R18. The problem is walang ganung exact size ang Otani KC2000 na model. Based sa manual, the 2018 XV accepts two sizes:
225/60R17
225/55R18
May sense bang mag downgrade to a 17"? If I want to keep on using a 225/55R18, which brand and model would you guys recommend na ka-range lang ng Otani? Btw, the stock tires are Dueller.
- Mar 2013
- 6,160
February 2nd, 2023 08:28 PM #38You can't downgrade to 17" because you will have to change your Rims as well.
Sent from my SM-G998B using Tsikot Forums mobile app
- 54,262
February 2nd, 2023 08:58 PM #39
- Feb 2013
- 927
February 2nd, 2023 09:14 PM #40Then why does the manual say it accepts both?
Do you mean "one MAY CHANGE tyre diameter without changing rim size" instead? I was just thinking out loud if I don't find the exact 18" tire size, at least I have the option to go 17". But I don't know what the disadvantages are if I were to downgrade.
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
