Results 61 to 70 of 72
- Feb 2013
- 893
February 6th, 2023 12:32 PM #62
February 6th, 2023 12:53 PM #63
I see no reason why not. I also go to Pampanga around once a month.
Not sure about your dealer but I trust my source. I guess it is better than no warranty at all.
Since Taguig ka naman, madali lang Punta to my preferred shop in Angono. Ako nga, Paranaque pa pero dinayo ko yun kasi tiwala ako doon.
- Feb 2013
- 893
February 6th, 2023 03:15 PM #64Yeah, mas mahal lang kasi yung sa Angono at 5400/tire. Yung sa Banawe (Excellent Marketing, binigay din sakin mismo ng Otani Philippines as one of their authorized dealers), 5200/tire lang. PERO, ngayon ko lang narealize na 5 years warranty nga pala yung sinabi sakin sa Olympian Tire Shack! So I think the price difference is worth it kung ganun.
- Feb 2013
- 893
February 10th, 2023 12:16 PM #65Just had my Otani KC2000's installed at Olympian Tire Shack. And yes, it looks like my wheels needed alignment too, which probably explains the uneven wear on those old front tires I had. Here's the alignment report:
A couple more questions:
1. Because the stock tires were already replaced, do I still follow the recommended tire pressure that's indicated by the driver-side door?
2. Do you have any recommended aftermarket TPM systems that I can have installed in my tires?
February 10th, 2023 03:00 PM #66
Yes, you need wheel alignment. By the looks, you may have suspension issues. Sana bushings lang at hindi shock absorbers.
Just follow the same air pressure as indicated since near to stock naman new tires mo.
- Feb 2013
- 893
February 10th, 2023 03:02 PM #67How were you able to conclude that I have suspension issues? Eto kaya yung sinasabi ni FusionR last Oct 2021 na kailangan na palitan yung bushings ko kasi malaki na "punit"?
Tinanong ko kasi sa mechanic sa Olympian Tire Shack kanina, sabi niya "ok naman" daw yung mga sa ilalim ng car. So not sure if that includes the bushings and all.
February 10th, 2023 03:13 PM #68
- Feb 2013
- 893
February 10th, 2023 05:24 PM #69I agree. Although that's what he answered me when I asked if the there are any worn parts like bushings, rack ends, and tire rod ends (which is what whistler told me that they'll check before doing the alignment). Initially, he did life the care and shook one tire when he was replacing the tires to eyeball if there are alignment issues. He right away said they're misaligned and the computer supported that claim when it was time to use it.
February 11th, 2023 12:38 PM #70
Sabi ni Whistl3r oks nga daw as per his technician. What you can do is to observe for tell-tale signs of suspension bushings wear. You would know if you have worn out bushings when you hear that shudder while going over 80 kmh or when shifting lanes at speed.
Toyota GR86 Owner Says Toyota Denied Warranty After Engine Exploded on Track | The Drive
2021 Toyota 86
