Originally Posted by
dr. d
the tyre diameter will literally dictate the rim diameter size, and vice versa.
a tyre diameter of 17 inches will only fit into a wheel diameter of 17, and a rim diameter of 18 will fit only tyres with an 18 inch diameter.
tyre diameter refers to the size of the empty space in the tyre. rim diameter refers to the distance between two opposite edges of the rim. or something like that.
tyre circumference figures directly into the car's dashboard's distance- and speed-measuring instruments.
tyre charts will show tyre changes from one size to another, with the corresponding changes in tyre circumference.
the objective of these tyre charts, is to ensure that changes in tyre circumference are kept to a minimum, when changing tyre diameters.
the manual knows about the above, hence its statement that it can accept both.
note that another potential problem with tyre size changing, is that sometimes the bigger (fatter) tyre might rub onto the car's metal under certain maneuvers.
best to ask the knowledgeables first, before purchasing yon tyres.
