Results 1 to 20 of 72
    Feb 2013
    I've recently noticed that the aircon of my car is blowing hot air when stationary or when in traffic. It has no issues when the car is in motion. I remember I had the same issue with my family's Montero before so it looks like a common issue.
    Who do I bring my car to?
    Bring it to any AC shop and have your fan check or you can check yourself if fanas is working.
    Feb 2013
    So car aircon systems don't really need any special handling and most auto mechanics can diagnose (and fix) the problem with ease?
    Quote Originally Posted by kevindd992002 View Post
    It's all the same, hinde mo pa din Napa check? You even check the fan yourself if it's working.
    Feb 2013
    Hindi pa din, super busy with other things since last week. Nagcocomplain na nga si wife, haha. I'm a super car noob and I need to check the manual muna kung san mismo yung ac fan. Last week, nag eyeball lang ako and saw two fans in front of the engine and gumagana naman sila. Not sure if one of those is the ac fan or not though.
    Sent from my SM-S916B using Tapatalk
    Apr 2005
    Coolmate (Denso) at Vito Cruz extn. cor. Kakarong St. Makati near South Cemetery. But I think you need to set an appointment first before going. 8892-4931
    Feb 2013
    Good prices?
    Aug 2004
    Medyo malayo pero I had our XV's evaporator replaced by EEB Aire on Timog. You have to call ahead to ensure that parts are available though. Layo ng price diff compared to the quote from Denso BGC.
    Feb 2013
    Timog is fine for me kung malaki naman price difference. Ano symptoms ng sirang evaporator?
    Aug 2024
    When you say, “Layo ng price diff”, which one fixes the problem at a lower price?
    I also have a Subaru Forester, 2010 and AC not cooling.
    Kung mahina buga ng aircon ng Subie nyo, you can follow these steps:
    1. Check freon pressure; recharge if needed
    2. Check for leaks; replace o-rings if needed
    3. A whining sound coming from your compressor upon engine start means it is lacking oil. Refill compressor oil regularly to extend life of compressor (2k fix including freon recharge).
    4. If no leaks within hoses and still losing freon, check expansion valve. Replace only is the option for a broken expansion valve (worth 5k for the whole fix).
    5. If no leaks and expansion valve is good but still losing cool air (or freon), check evaporator. Replace and then clean whole system (worth 14k for the evaporator plus all the other services).
    6. If no air coming out from your aircon system, compressor might be dead already. Replace it and, check both evaporator and expansion valve.
    A good aircon shop can do all these things. The big challenge will be when you need to source out a broken compressor.
    Feb 2013
    Thanks as usual, Egan.
    Update to my issue:
    Binalik ko sa CarTech service center and they were firm na hindi na daw kaya ng compressor yung freon spec amount na 400g. At hindi din daw sila nag totop up ng compressor oil. Dapat full flush daw yung gagawin which costs around 6K. They tried bringing it up to 400g again pero ganun parin talaga.
    I brought it to Coolmate thinking na magiging mga 2K lang din yung freon recharge plus compressor oil top up. The discounted quote I got was 3K when I was there. Nag go na ko and recharge nila to 400g plus 40cc's of oil directly put sa compressor. Nawala significantly yung noise and it looks like my problem is solved. O-ring lang talaga cause ng leak.
    Lesson learned talaga dito na hindi "it's all the same" ang mga gumagawa ng aircon. Na doble gastos ko because of that. Kung from the start pinagawa ko na sa EEB Aire (malayo nga lang kasi from my residence) na 1.8K lang ako kasama na freon recharge, o-ring replacement, and compressor oil top up dun.
    Also, walang kwenta ang CarTech service center Taguig, hehe. I'll never go back to that shop.
    Update to my issue:
    good for you, po!
    yes, auto aircon technology is "all the same".
    but the people running the shops, they's not all the same.
    truly, some are more honest and more knowledgeable, than others.
    Feb 2013
    good for you, po!
    The it's all the same concept I'm referring to is the quality of work that different shops do, not the technology itself.
    welcome to the exciting new world of ex-casa car maintenance!
2018 Subaru XV Aircon Problem
