Results 471 to 480 of 1640
January 11th, 2011 01:09 PM #471
January 11th, 2011 02:19 PM #472
January 11th, 2011 02:46 PM #473
Parang ito na yung solusyon sa problema ko,1 week na yung rattling sound sa clutch at pag na depress nawawala din. Sarap talaga yung thai spec na strada, aux fan + oil cooler. Bat kaya yung na release sa atin wala?
bit o.t: sir dadz, may nakita na akong good shop to make the spacer para dun sa driveshaft. Thanks for the tip.
January 11th, 2011 03:04 PM #474
Mga sir's the price of the clutch is the dealers price avail habang wala pa po akong dealer na mag handle nag product but siyempre pag me dealer na doon na po tayo bibili medyo iba na po ang cost, i only offer this for the BOSB.
January 11th, 2011 07:10 PM #475
dadz buti nakahanap ka na ng racing clutch, mura yung 11K ha!!! actually kahit hindi ka naka 4x4 mas maganda na mag 4x4 lining and plate ka na, para mas tumagal ng kaunti pa... sayang kapapalit ko lang ng set ko last month, pero the way i wear my clutch down baka december this year palit na naman!! hehehehehe
tapos bakit ako may oil cooler? yung ibang mga units wala ba? kumpleto naman mga cooler ko, 4 sila lahat kasama na yung sa a/c dun, ang ikakabit ko na lang is yung auxiliary fan, medyo tinatamad pa ako eh.... hehehehe
January 11th, 2011 07:45 PM #476
January 11th, 2011 09:09 PM #477
January 11th, 2011 09:26 PM #478
January 12th, 2011 05:01 AM #479
January 12th, 2011 08:43 AM #480
*dadz
where you able to check his radiator ? baka kasi integrated na sa radiator and coolers meaning, if you look under the radiator meron extra small hose naka kabit doon going to the a/t , Instead of the normal small radiator for a/t. yun sa old accord,revo and avanza ko ganyan ang stock na nakakabit all integrated. kaya pag nag palit ng radiator, pinapakita ko yun old radiator picture with those extra hose and neck sticking out sa ilalim
*g01 or kung sino yun naka matic, check nyo sa radiator pang ilalim ilang hose ang nakikita nyo nakakabit sa radiator.
re: Auxilliary fan, i already ask this sa Casa, sa philippine version, montero lang daw yun kasi dual AC and it is used for the AC cooling coil daw
Pwede din ba gamitin yun aux oem from montero, di ko lang sure kung saan ikabit ang wiring ng aux fan, meron bang water temp sender sensor ang strada para doon ikabit ang aux fan for automatic on/off? baka pwede mo kami bigyan ng diagram ng aux fan mo saan sya nakakabit?
Re: clutch, ano difference ng oem clutch sa racing clutch ? kelan ba usually nag papalit ng clutch? (mileage or years?)
Thanks.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
