Page 42 of 82 FirstFirst ... 3238394041424344454652 ... LastLast
Results 821 to 840 of 1640
    Jan 2008
    #821
    i almost forgot, regarding the a/c filters for the strada.... i just finished fabricating/installing a filter on my unit. i will post the pics when i a done uploading.
    as for the cost of the installation, it won't be expensive, and it will only take me an hour or so to finish it.
    i'm still trying to source a more cheaper element though before i formally offer it to you guys!!!
    Quote Originally Posted by djoverdose View Post
    Guys question.... i was browsing awhile back and i came across with DIY boosting with washer mod placed in between the wastegate and the compressor.
    question is napaka tagal na kasi nung thread na yun at the same time hindi pa crdi yung 4d56 that time.
    have anybody here tried it again sa 4d56 CRDI? any gains? thanks guys.
    Si sir KCboy na-try na ata sa CRDi 3.2 strada, no improvement ata. Pang-non crdi 4d56 with M/T lang atan yan effective. No big improvement din sa mga A/T tranny eh AFAIK.
    Quote Originally Posted by marlowem View Post
    Will look into Coopers, angas nga nung mga mud tires kaso daily driven baka maubos agad hehe. Salamats!
    Quote Originally Posted by doy View Post
    Cooper Discoverer STT has shorter thread life compared to ATR (same with all mud-terrain tires). Ok lang kung hindi daily driver ang truck. Pero maporma talaga ang mud-terrains.
    Based sa reviews ng mga naka-cooper dito sa amin, mas matagal siya mapudpod kesa sa Dunlop at Bridgestone. I don't know if its 100% accurate ha.
    Jun 2008
    #823
    Yes sir this works only if your boost cut control is already bypass every 1mm of washer is equal to 1psi of boost, but if you still have the boost cut control wala po siyang effect.
    Apr 2009
    #824
    ry_tower and Dadz,
    Thanks for the advice sirs.. was planning to do this pa naman. sayang....
    anyway kakapa change oil ko lang kanina then afterwards i went to a muffler shop here in Las pinas and i had my muffler removed and replaced it with a straight pipe with resonator. mas magaan ngayon tumakbo yung strada at mas dinig yung spool ng turbo.
    yung washer Mod sana isusunod ko eh.
    Jun 2010
    #825
    ry_tower and Dadz,
    Pa post naman pics nya sir nang may magaya
    Dec 2009
    #826
    hi to all, just wanted to ask were can I buy new A/T tires for my strada gls
    I will be retaining my strada stock rims. currently my tires are 245/65R17.
    Are there 245/65R17 A/T tires? if not my option is 265/65R17 A/T tires.
    do you guys know were to find them?
    thanks and more power.
    Apr 2009
    #827
    Quote Originally Posted by EkwinOKS View Post
    alin dun bro? kung yung sa washer dito ko lang din sa tsikot nakita eh.
    if its about the muffler. very easy. just go under your pick up and make sure you have a size 14mm back wrench with you. locate the flange of your exhaust.
    nasa right side near the rear door mo ito. it only have 3 bolts. yun na. you can try to remove it para malaman mo yung feel pag wala yung muffler. kung tutuusin asteeg nga tunog pag wala. you get a low growl from the engine plus pag nag boost iba. ang bilis umangat ng rpm also the turbo whine is more audible even at 1.5K RPM.
    ang na notice ko lang at low speed ramdam mo talaga na mas magaan yung takbo. pero pag long distance, may time na pag shift mo ng gear(M/T) parang kulang pa sa bilis.
    hirap i explain eh. kasi since mas maluwag na tumakbo halos at 4th gear nasa 80KPH nasa 2k rpm ka palang pa spool palang yung turbo. kaya pag nag 5th gear ka it will go down to 1.8K RPM so medyo parang under gear bigla pero after you step on the gas few sec after ok na uli.
    kaya ginagawa ko pinapaspool ko muna yung turbo bago mag shift. nakaka panibago pero once naman nag spool yung turbo ramdam mo yung hatak.
    specially kung naka drop in filter ka pa.
    I hope na medyo mas tumipid ako sa krudo ngayon. since pag hindi highway driving eh below 2K RPM lang lagi takbo ko at ok na yung speed niya.
  8. #828
    Quote Originally Posted by mrm43 View Post
    Good day Sir,
    I am using Dunlop AT3 tires (245/70/16), got it from a shop at Evangelista for 5900.00 each... medyo madulas lang sya pag hi-speed at basa ang karsada pero hindi naman gaano maingay.. not sure kung meron din ganito sa 17" rims...
    Jan 2008
    #829
    Sir Welcome sa thread, Yung President ng club natin naka 265/65R17 A/T Tire on the stock rim ng GLS Mickey thompson medyo mahal nga lang.. Kasi pag 17" yung rim the cheapest yata is around 6.5K.. Try mo din federal tire na A/T yung couragia maganda sya.. may discount kung member ka.. Kaya pa member kana sa friday
    Dec 2009
    #830
    Quote Originally Posted by alainroyce View Post
    Hi, thanks for all the quick replies. Maganda nga couragia. Saan kaya sa mga
    dealers available itong federal. thanks again
    Apr 2011
    #831
    SIr..Magandang araw po... pwede ba ask sau kung saan tayo makabili nang ganito dito s metro manila na store...sana sir matulungan nyo po ako kasi kailangan ko po .....hihintayin ko po reply nyo.....maraming salamat po...
    Jan 2008
    #832
    Quote Originally Posted by sijimore View Post
    Welcome sa TSCP Club.. I don't see any picture you mention.. Tires ba?
    Jan 2008
    #833
    Please check our website... http://www.stradaclubph.com/
    nasa signature ko din..
    Aug 2009
    #834
    you can try Cooper Discoverer ATR. I got my 265/70/17 for 6.4k+ only. Good reviews din. I got mine at RYCO in Aguirre, Makati. Happy modding!
    Apr 2009
    #835
    Dadz,
    sir dadz yung boost cutoff ba eh naka prog sa ecu?
    Dec 2009
    #836
    Quote Originally Posted by nanofossil View Post
    Hi, thanks again.
    Aug 2007
    #837
    Dadz,
    performance chips ata..
    Dec 2009
    #838
    hi mga sirs, ask lang ule. Kung papalitan kulang yung tires ko at retain yung
    rims (gls 2010), tapos gamitin ko 265/70R17 A/T. As is lang ba? wala ba akong
    momodify like suspension, offsets etc... Paano din pala magiging ride? Mas magiging matagtag ba at ung FC mas tataas ba? Thanks again
    Sep 2010
    #839
    Sir, wala naman dapat palitan sa mga pangilalim ng truck mo if ever magpapalit ka ng tires pero kung gusto mo naman tumaas pa yung truck mo pwede mo palift mo na lang. I hope this would help sir...
    Jun 2008
    #840
    Dadz,
    Boost cut control is available in 2 modules one separately connected to the MAP sensor and the other one is included in the performance chip(PiggyBack system).
    Tama yung gawa nyo sir exhaust change is better and cheaper will give you about 5hp of additional power. Just dont go to big 3 inch exhaust pipe is to much a lot of people will argue but that is base on our mods na we tested already.
TSCP Strada Mods [continued 2]
