Results 1,351 to 1,360 of 1640
October 13th, 2011 08:16 PM #1351
October 29th, 2011 08:03 PM #1352
Share ko lang po po (how to improve the sound reproduction of the stock 2010 Strada GLX audio system):
1) Turn off loudness and defeat.
2) Turn on HPF (high pass filter) and set to 100Hz.
3) Set bass center frequency to 200Hz and increase to +3 with 4 width (widest parametric eq setting).
4) Set treble center frequency to 10KHz and increase to +3.
I observed the sound reproduction to have more body and bite with some frequency extension (airness) and crisp even without tweeters (6.5inch dual-cone speakers lang ang stock sa doors). Midbass hits with some RnB and Hiphop tracks are punchy and without distortion even at volume 9.
- Oct 2011
- 16
October 31st, 2011 09:28 PM #1353Meron na po bang naka pag pakabit EGT at Boost Gauge sa Strada nila. Para kasing ok din makita ang boost at temp sa dashboard. Yung kaibigan ko nag pakabit pero sa montero na VGT at umaabot daw sya ng 25psi ang boost.
- Feb 2010
- 7
November 15th, 2011 01:57 PM #1354mga sirs here is a pic of my truck. I am planning to change the rims from 16x8 to 16x10. Gusto ko sana lumabas pa ng konti from the fender. Question, hindi kaya sya mag rub pag full turn? Stability issues? At kung saan po pwede bumili ng mura. Your opinions would mean a lot. Thanks!
November 16th, 2011 01:10 PM #1355
- Feb 2010
- 7
November 16th, 2011 05:22 PM #1356+20 ang offset. Also nag lagay ako ng 1/8" spacers front and rear para lang lumabas ng konti. Pero bitin pa rin. Thank u for the insight bro..
November 18th, 2011 12:55 AM #1357
if you want lang naman na lumabas yung mags and tires what you need to have is a negative offset wheels....=) masyado na malapad 16x10 IMO and hindi na yun kaya ng 265 iacommodate...
November 18th, 2011 01:05 PM #1358
Yup, hanggang 16x9 lang ang 265/70r16 or 265/75r16. Pwede din bolt-on wheel spacers gaya nito:
http://image.4wheeloffroad.com/f/245...l_adapters.jpg
Pero mahirap ata maghanap ng 6x5.5 (139.7 pcd) to 6x5.5 (139.7 pcd) pattern.
- Sep 2011
- 13
November 19th, 2011 01:09 PM #1359finally, nakakuha na rin ako shoes for my 2010 GLX! pa'no po ba mag post ng pics dito? hehe..
got 16 x 8 offset +20 (as advised by people here) and PERFECT siya for me since wala ako fender flares. looks great with 265/70/R16. achieved around 1/2 inch from the edge of my fender and no issues when turning, etc. (again, as indicated by my "advisers" on this thread). salamat ng marami!
kung may flares, baka ok +10 or even 0 offset. ganda siguro nun since ang lapad ng inner lip! my two cents..
on to another topic, meron na ba source dito sa pinas ng honeycomb grills (ie. stock on triton releases in thai, australia, etc.)? tagal na'ko naghahanap. if wala, has anyone ever tried purchasing online? any issues with customs?
thanks ulit mga sir!
- May 2011
- 191
November 19th, 2011 01:59 PM #1360^ I like to make a PRIVATE album on Facebook and put all my hosted pictures on there. Get all the image links from the individual pictures, then post a reply here sa tsikot, and paste each of the links after pressing the image button above.
Xiaomi E-Car
