Results 3,671 to 3,680 of 3844
May 30th, 2014 03:26 PM #3671
oo sir roldan dito ako pilar las pinas... napalitan ko na expansion valve at manual thermostat pero ganun pa din...medyo nawawala lamig pag menor pero pag tumakbo na ayos naman lamig nya... s harap lng nawawala s rear a/c naman ok...anu kya problema nito?
Posted via Tsikot Mobile App
May 30th, 2014 03:28 PM #3672
May 30th, 2014 03:38 PM #3673
napansin ko s aircon pag naka menor wla lamig s harap s likod meron..bago linis naman...bgo expansion valve at thermostat nka set s 3/4...yung compressor nsa 45 reading at bumababa pa pag apakan accelerator,condenser bgo s harap may sub condenser s ilalim reading ng hi side 175-200... di ko n alam kung anu p problema ng aircon ko ehh
Posible bang clutch fan din mga sir?
pag naglagay manual thermostat tatanggalin b lumang thermostat na orig? parang nkita ko ksi nag tap lng s dati....
May 30th, 2014 03:55 PM #3674
June 1st, 2014 01:19 AM #3676
June 1st, 2014 01:22 AM #3677
welcome po sir, merong nagpost ng mga materials needed sa idle up natin pero diko na mahanap ,heheeh
nga pala nagpa change oil ako kanina, kalain niyo po , loose thread na pala yung drainage ng oil sa oil pan , kaya ayun inoversize na ng pinagpa chage oil lan ko, sabay palit nadin ng transmission gear oil, gumamit ako ng nabanggit dito na gear oil SAE 140
June 1st, 2014 07:35 AM #3678
akin din sir feti...na loose thread na kaya oversize na din s goodgear...kaya ingat pag nagpapa change oil...maganda yung binebenta n gear oil s rexstar... hindi maingay transmission ko, mag 2 years na..zic ata brand...
June 1st, 2014 09:23 AM #3679
Sakin lalo na... Size 17 na nga nakalagay.... He.he....
Sent from my C2305 using Tsikot Forums mobile app
June 1st, 2014 11:40 AM #3680
[QUOTE=john1ortega;2357776]akin din sir feti...na loose thread na kaya oversize na din s goodgear...kaya ingat pag nagpapa change oil...maganda yung binebenta n gear oil s rexstar... hindi maingay transmission ko, mag 2 years na..zic ata brand...
gusto ko din sana subukan yang brand na zic kaso ala ako mahanap dito samin eh , okay lang kaya yung castrol na dsl oil mga sir? yun kasi yung ginamit ko
[QUOTE=glenn manikis;2357797]Sakin lalo na... Size 17 na nga nakalagay.... He.he....
parehas tayo sir glenn ganyan nadin ang size nung akin , nadadali daw kasi yun pag sobrang higpit
ang hirap pala magpalit ng glow plug, pinalitan ko kasi #3 na glow plug ko, buti no 3 yung nadali, masmadali lang palitan ,
Top Gear taking a cue from journalists scouring patent applications of tech companies.
Mitsubishi Philippines
