Results 3,361 to 3,370 of 3844
April 16th, 2013 09:10 PM #3361
depende po sir kung me oil flush kayo ilalagay niyo muna po yoon tapos start for about 5 min. or 3 min and then drain po ninyo ang oil buksan ang drain plug sa ilalim... kung me compressor po kayo hanginan niyo po para mas mabilis bumaba/lumabas yung oil make sure walang tubig na humahalo sa compressor niyo dapat me filter kayo na nag separate ng water sa air, kung wala mag overnight nalang po kayo, yun ang the best hayaan niyo lang po tumulo ang langis mag-damag and then yung oil filter ang ginagamit ko po doon ay kadena lang po... after mapalitan ang filter takpan na po yung drain plug lagyan niyo nalang po ng silicone yung takip ng oil filter at drain plug para sure na walang tagas... and then ilagay niyo na po yung 6 liters na oil ola presto start the engine but don't rev it up let the engine run for a while in a idle manner...
- Sep 2010
- 60
April 16th, 2013 10:24 PM #3362
April 17th, 2013 12:30 AM #3363
I just oblonged another pair of Nankang Super Trippers. The 2008 ones, were replaced in December 2012 and the 2009 production ones were replaced today again with Nankang Super Trippers.
The dealer said that too much tire pressure might be causing the tires to become oblong. I'm just wondering what tire pressures you guys are running. Door placard says 45psi unladen and 55psi when laden.
My MB100 can only seat a maximum of 4 persons plus one patient in the back area. Is 32-35psi ok? I run on the NLEX everyday.
Thanks guys. Thank you sir glenn for texting me your feedback on this query.
April 17th, 2013 12:32 AM #3364
April 17th, 2013 12:42 AM #3365
Sir Otep, Ako po lagay ko sa gulong ko is 45 lahat, weekends akyat ako ng baguio with 7 adults balikan then pag city driving dito sa la union mga 6 adults including me. Maxmiller CX (GT radial) ang gulong na gamit ko po.
- Mar 2013
- 43
April 17th, 2013 09:17 AM #3366
April 17th, 2013 09:44 AM #3367
Yes, plastic siya so be careful. Yung sakin may silicone na din sa thread kasi nagka minor leak na over the years.
April 17th, 2013 10:03 AM #3368
April 17th, 2013 11:05 AM #3369
Yung slave cylinder na may rubber cup nasa Php500 ata sa Banawe pero wala ako nabili na orig. *** Chu ata brand. Ganun din ang naka-stock kina Apic na item. So far so good naman. hehe.
April 17th, 2013 12:27 PM #3370
Bale yung tumatagas po is dun sa may bandang loob po ng driver side, sa may apakan ng clutch. Nagpalit po kami ng rubbercap nung in-house na mechanic ng 1st owner ng van na nagkataong kapitbahay namin. Nagpalit na rin daw sila ng clutch slave cylinder and rubbercap din last october 5.2012.
Napansin ko na ayaw nang pumasok ang 1st gear 2 weeks ago so nagpalit kaagad and ang nabili ko na replacement is parang plastic yung ulo niya. Tapos yun na after a week, naramdaman ko nang sumobra ang lambot pag aapak na ng clutch then nagcheck na ako, ayun may tagas na naman.
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
