Results 2,811 to 2,820 of 3844
- Aug 2012
- 4
August 16th, 2012 05:32 PM #2811
- Aug 2012
- 4
August 16th, 2012 05:38 PM #2812
- Aug 2012
- 4
August 16th, 2012 05:45 PM #2813
August 17th, 2012 09:47 AM #2814
sir jonlan ganyan din po yung sakin may time may grinding sound... pina check ko na wheel bearing wala naman alog at maganda din ang kayod ng preno sa brake disc.... at pag tinaas at pinaikot wala din naman grinding sound pag matulin ang takbo like even at 120 wala din pong grinding sound..... pero pag tumatakbo lalo na galing sa stop may time na may grinding sound...... i think pag naka liko ang manibela at pag galing sa atras parang dun po ang dahilan ng grinding sound....
ill check my suspension, pa check ko muna camber baka naka tabingi ang gulong kaya meron sumasayad at yun ang cause ng grinding sound.....
sir jonlan ano pa kaya ang maaaring pinangalingan ng grinding sound?
sir FSALES.... kamusta na po mb nyo? balitaan nyo naman kami dito kung nawala na grinding sound ng van nyo.
August 17th, 2012 10:29 PM #2815
good pm mga ka MB, share ko lng, nasira power steering pump ko,pag U-turn ko ng todo, may grinding sound nung una , nasira yung bearing at nabasag yung pulley,napatid din yung fan belt, buti dito lng ako s alabang, nakatakbo pa s talyer, presyo ng parts...
steering pump 3k surplus, bago 6.2k s goodgear,
fan belt 550 s rexstar,
return hose power steering 370 orig ssangyong s rexstar..
yung shock s tailgate 440 replacement s goodgear,
fuel filter 150
pre filter 85
labor 1300
- Mar 2012
- 12
August 18th, 2012 07:03 AM #2816
- Mar 2012
- 12
August 18th, 2012 07:07 AM #2817
August 18th, 2012 09:12 AM #2818
August 18th, 2012 05:03 PM #2819
- Sep 2010
- 60
August 19th, 2012 05:48 PM #2820Good day po sa lahat!
Sir Jonlan question lang po, kasi yun van ko pagmalamig ang makina palyado ang andar at may puting usok na lumalabas sa tambutso, ano po kaya ang sira nun.Thanks po.
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
