Results 2,071 to 2,080 of 2730
- Jun 2007
- 26
September 15th, 2009 02:00 PM #2072
hindi ko rin sigurado, pero parang fabricated cotton, pero ok narin yata kung foam.
September 15th, 2009 07:42 PM #2073
sir, huling kinabit ko Gates brand (US). 2 years na mula nun. tantya ko sa december ako ulit magpapalit. every 2 years kasi ako para sure na di maputulan.
meron na ba sa inyo nakahanap na clutch release bearing na bakal? sabi kasi sakin sa goodgear plastic lang daw talaga ung gawa na release bearing para sa mb kaya madali madurog at umingay.
September 15th, 2009 10:58 PM #2074
i sell mitsuboshi brand fanbelts.. pati timing belts meron..
pag.. with tooth like what the mb100 uses its made in japan.. and made in philippines if plain...
this brand is used as oem in bnew mitsubishi vehicles
i use it on our family mb100..
price for mitsuboshi 6pk-2100 is 1550 less 10% can be picked up in qc/malabon or binondo
but sure buy dapat since pre-ordered po ang stocks
pwede din po ipadala via air21 + 200php charge
thanks
September 16th, 2009 09:05 AM #2075
paano malalaman na pwede ng palitan ng fan belt? yung nabasa ko dito nag e e slide daw o kaya maingay?
September 16th, 2009 11:24 AM #2076
sakin sinisilip ko yung fanbelt every change oil. normally makikita mo na maguumpisa magkaron ng crack along ng fanbelt (pahaba). pag malala na yung crack, saka ko pinapalitan. napansin ko mga 2 yrs ganun na. unless di magandang belt. nangyari na kasi sakin yun 1 beses di maganda nabili ko kaya after 6months palit agad. 700php ata bili ko, di ko maalala brand. mura nga pero saglit lang din sira na.
experience ko lang yun. sana makatulong.
September 19th, 2009 12:36 AM #2077
question lang mga bro, naexperience nyo na ba na parang hirap ipasok sa 1st gear yung mb nyo? sign na ba to na kelangan na ulit palitan ung clutch parts?
September 19th, 2009 04:15 AM #2078
try mo muna ipa adjust ang clutch pedal yung akin kasi nagkaruon ng sabit sa 1st gear at 2nd gear pag kababa ko galing baguio, pero pinaadjust ko naging ok naman , or try mo tingnan yung goma na nasa clutch pedal baka sira na?
- Jul 2007
- 345
September 19th, 2009 05:03 PM #2079hi pinsans... kamusta na ang mb's natin... yun pala nabusted na mukhang fuse na nagpapagana nun rear ac ay hindi talaga fuse... di ko alam ang tawag pero it seems na affected ang maraming bagay like horn, ac controls, at pati pwer locks... unfortunately di ko pa naactionan, i-rekta ko muna for awhile just to make rear ac work
kamusta na sir seleg/ sir aga/ sir glen... and to every-all
- Sep 2009
- 23
September 20th, 2009 10:13 PM #2080
Kapag tinuloy pa yan sigurado magtatagal dahil makikialam ang Taguig LGU.
Makati Subway. Completion date: 2025
