Results 21 to 30 of 58
August 18th, 2006 10:12 PM #22
....grabe umaabot pala ng 10k ang ganun. di ba kaya ng ponstan na lang?
August 18th, 2006 11:05 PM #23
that would be possible as ive written as one of the indication of rct, intentional rct, there are some tooth can could be done one one sitting, if there is no existing lesions which are better viewed and diagnosed with xray, then root canal treatment could be done in one sitting=)
however if the case would have a chronic problem such as presence of abscess, lesions, granulation tissue, then that will be quite difficult to be done on one sitting, because the goal of root canal is to render the canals sterile=)
prices really varies depending on the dentist, to those who charge high check their competency and testimonila from other patients, from those who charge so low, check their quialification just for verification=)
scarab - di kakayanin ng ponstan lang, ponstan is mefenamic acid, the course of its action is pain reliever and control of swelling, but it doesnt include bacterial control which antibiotic does, if you would ask if antibiotic alone could do the triuck, well in some minor cases, it is possible, coupled with adequate diagnosis of the tooth, proper tooth filling is also indicated to prevent recurrence of any pathologic disturbance=)
August 18th, 2006 11:26 PM #24
scary yung ponstan.
kasi if the tooth is severely infected, the injection can spread to the jaw. mapapatay ka pa nun.
yeah, hard to believe, pero a decayed tooth has the potential to kill you. Or pwede rin, ma-inject yung jaw bone mo and it has to be cut. magiging para kang si Darth Vader (without the mask).
i made the mistake when i was younger to ignore caries. ayun umabot sa point na di na kaya i-restore. bungi tuloy ako actually missing two molars. ang mahal mahal ng fixed bridge!!! sobra. and i'd need two of them. kaya di ko pinapagawa hehehe.
if you think an RCT is expensive, mas mahal ang fixed bridge.
and mas mahal pa dun ang titanium post.
August 19th, 2006 12:26 AM #25
....hehehe, was kiddin' bout the ponstan alone. pero totoo naga ata yung post nung isa. just had my tooth filled by a "new school" dentist. pansin ko nga mababaw na lang sila mag-drill unlike my fillings before nung bata pako, ang lalim talaga ng mga dentista nun mag-barena. ang saket pag binubugahan na ng hangin.
August 19th, 2006 01:05 AM #26
Nasa last month's reader's digest yung death or serious illnesses due to dental problems.
Ako sumakit na lahat wag lang ngipin ampuch... di ko talaga kaya yung sakit...
Pahabol...
Nakita ko sa newspaper yung ad na laser na gamit (no-drilling), di daw masakit...
Laking difference ba sa presyo?
August 19th, 2006 01:34 AM #27
thanks sa mga reply.
ok na rin ung sa gf ko. ok na daw sabi ng dentist. wala na daw amoy kaya pwede na sarahan. pag balik niya sa next session sasarhan na daw.
August 21st, 2006 12:13 AM #28
dental problem especially badly cariuos and infected tooth could lead to a heart problem (sub acute bacterial endocarditis, SABE) so be cautious of it=) read on last months readers digest=)
flakez- nice to hear your gf tooth is doing well=)
theveed- laser used in preparing and removing the decayed tooth in preparation for a filling would be quite pricey, right now im using the high speed drill, there are tecniques and ways to lessen the pain and sensitivity while debriding the decayed portion of the tooth=)
orly_andico- if cash would not be a problem i would suggest that you go for dental implants, its is much better than fixed bridge=) if you do have plans to have them but in short of cash, i would suggest that you save money for it, while doing so, you can have a removable denture first so you can have something to chew on, then after saving enough cash proceed with dental implants=) and choose a dental implantologist to have your implant placed dont settle for a so-so dentist to place them in, its quite pricey enough so better be safe and see a competitive dentist who install dental implants=)
August 21st, 2006 12:29 AM #29
classmate ko ng college ,namatay bagong bunot ng ngipin ,
naholdap ,nanlaban .nasapak ng holdaper tinamaan sa mukha ..
wala tigil ang pagdugo .namatay sa hospital
cousin ko din .bagong bunot .nawala sa loob nagbuhat ng mabigat dinugo balik agad sa dentist(lapit lang ng clinic sa house) ..
dami nilagay na malamig sa bibig mejo humina ang pagdugo
at tuluyan nawala
Doc cutedoc,ano ba mga dapat gawin or iwasan pag bagong bunot ,
plan ko kasi naman mag pa extract next month
TIA
August 21st, 2006 01:04 AM #30
for a more proper procedure
1. consult your dentist, he would ask about your medical and dental history, this is important, like if you have exixting diabetes or heart disease it should be known to the operator,proper medication will be prescribe
2. after surgery or tooth extraction, pack in the cotton or sterilized gauze every 15 min or until bleeding stops
3. put ice pack in the area within 24 hours as the case may be simple tooth extraction, 3-4 hours is enough
4. take medication for pain,swelling, and antibiotics as prescribed
5. avoid hot food as these may cause bleeding
6. no smoking and drinikng before and surgery
7. brush teeth after eating, gargle with mouthwash or saltwater
8. dont play with the extraction site, dont use fork, toothpich or finger to poke the wound
high idle RPM at engine start
