Results 101 to 110 of 2560
Zombie
- Aug 2006
- 728
August 23rd, 2007 09:16 AM #101these is what we do on all our cars, including my itlog.
- 5,000 km change oil and oil filter (check and clean air filter)
- 10,000 km change oil, oil filter, and spark plugs. check air filter if replacement needed
- when i hit 40,000 km, i have a my fuel filter change and also have my valve clearance adjusted. if your vehicle is A/T, you change your A/T fluid too. have PSF checked too if it needs replacement.
as for your choice of oil brand, i believe any would do as long as you stick to one kind (don't switch from synthetic to mineral to synthetic). And stick to the 5,000km so your engine would perform better.
once a year i also have:
- a radiator flush
- aircon cleaning
- underchassis inspected > known problem of itlog. mas ok saken magpalit ng paisa isa kaysa one time bigtime. (cost me around 30k before).
- four-wheel alignment checked
- replace brake fluid
- belts checked for cracks and tightening.
hope this helps
hellboy:
that is not normal. i'm not adept with A/C maintenance though, so I can't help you with that.
cwebb:
something is wrong with your servo. dapat pinapalitan mo nalang.
- Aug 2007
- 2
August 23rd, 2007 11:09 AM #102Have a Mitsubishi Lancer EL 1995 edition, silver, in good condition and for sale 150K!
Please e-mail andrelou.pingol*heidelberg.com or contact me at 0917 8317415 (Andre)
- Aug 2007
- 19
August 24th, 2007 05:16 AM #103thanks torque 2006 for the info. bago lang talaga ako nagaaral about cars kaya every informations about itlog is a big help for me. Last tuesday nagpunta ako ng Laguna then back, mga 180 kms ang distance to test my itlog. Sabi nung kasama ko na taxi driver, alalay, bago lang kasi ako nagdrive, ok daw namang ang takbo walang problema. This saturday balik uli ako ng Laguna, this time with my family na. Thanks ulit bro!
- Apr 2007
- 13
September 8th, 2007 08:01 AM #104hI GUYZ,
Where can i find a shop in laguna-batangas area n ngtse-tsk ng servo. parang sira kac servo nung gli-96 ko. San rn kaya my available n surplus nito? any guyz here n marunong mg tsk ng servo?
thankz...
September 11th, 2007 11:44 AM #106
itlog owner here mine is a 95 EL mica red with some aesthetics mods and sound upgrades
- Aug 2007
- 19
September 13th, 2007 12:42 PM #107hello to fellow itlogers! sad story nabangga ako last monday, nayupi yung right side sa may front wheel ng itlog ko! konti lang naman damage nya, problema di nila yata marestore yung pintura, anzahl kc ang orig pinatungan ng nippon kaya ulit na naman. medyo marami na ring tama yung itlog ko kaya plano ko pa washover na lang. the quotation given to me was 25k. Reasonable na ba yung presyo? ganun ba talaga kamahal? Baka may alam kayo jan mga bro. Dito lang ako sa muntinlupa. Sna yung magaling, honest at hindi nananaga. Bagito lang kasi ako walang masyado alam sa cars, i got my infos dito lang sa internet. they even suggest to change my paint from anzahl to nippon, tama ba yun? what"s the difference between the two in terms of appearance durability and price. Info naman mga bro!
- Aug 2007
- 19
September 13th, 2007 12:47 PM #108I forgot to tell yung itlog ko ay 1996 glxi a/t navy blue kulay nya, wala pa mga upgrades, i'm still learning pa kasi, newbie lang. Regards sa lahat and Godbless!
September 25th, 2007 05:42 PM #109
ako may itlog mga brod!!!gwapo nga parang bagong pisa kasi naman bagong hilamos..95glxi
- Jul 2007
- 3
October 1st, 2007 01:54 AM #110mga sir, kailangan ko po tulong nyo. wala pa po akong alam tungkol sa mga sira ng sasakyan. ang oto ko po eh lancer glxi 93. pag nag 1st gear or 2nd gear po ako eh may sumasabit oh grinding sound at may time po na ayaw pumasok sa 1st gear. eh dalawang beses na po ibinaba transmission at pinapalitan yung clutch lining at preasure plate dahil yun po sinasabi ng mga mikaniko na pinagawaan ko at iniadjust na po yung clutch pedal pero ganon parin po. ano po kaya problema ng oto ko? sana po matulungan nyo po ako mga sir. thanks!
Means "Sedan" in japan... Sakanila yung civic na 1997 may ferio sa ilalim nang civic na logo at...
Civic horsepower
