Results 2,711 to 2,720 of 5235
- Jun 2007
- 207
July 28th, 2007 08:08 AM #2712mga sir,
gus2 nyo pa b palaksin dmax nyo? khit ala intercooler pwede un system namin na water/meth injection..or boost cooler..may mga satisfied dmax owners na kmi na kinabitan ng system..made and tested in the usa po un,,and applicable sa lahat ng turbo diesel..e2 po un gnagmit ng top diesel truck challengers sa usa to gain more power and to cool down their egt's....pm me nlng if interested for more details..
July 28th, 2007 06:15 PM #2713
GUYS,
Hanggang upgrade nalang muna tayo ng accesories ng old dmax natin, darating din ang araw tayo na naman ang may bagong DMAX!!!!!!!!!! 2010 HERE I COMEhaayyyy....
July 28th, 2007 10:56 PM #2715
- Jul 2007
- 1
July 29th, 2007 06:53 AM #2716hi guys im just new here in this forum... just like to share info about water injection.
Water injection is a method for cooling the combustion chambers of engines by adding water to the incoming fuel-air mixture, allowing for greater compression ratios and largely eliminating the problem of engine knocking. This effectively increases the octane rating of the fuel, meaning that performance gains can be obtained when used in conjunction with a supercharger or turbocharger, altered spark ignition timing, and other modifications. Many water injection systems use a mixture of water and alcohol (usually 50/50), partly because the alcohol is combustible, while water is not; in addition, the alcohol serves as an antifreeze for the water. Hence, water injection is also often known as methanol-water injection, owing to the fact that the alcohol mixed into the injection solution is often methanol, CH3OH.
Due to its corrosive nature, the alcohol in water injection systems cannot be ethanol. Only methanol and isopropanol are used, methanol being the more commonly-utilised form of alcohol for this purpose due to its higher availability and lower cost than isopropanol.
Water injection is often necessary when adding forced induction to an engine that was not designed for it; the compression ratio of a normally-aspirated engine is too high to cope with more than a very modest boost, even with retarded ignition timing, unless this technique is used.
The system was first used extensively on World War II fighter aircraft to increase power upon takeoff and bring up the service ceiling. A limited number of road vehicles with large-displacement engines from manufacturers such as Chrysler have also included water injection. Saab offered water injection for the Saab 99 Turbo. With the introduction of the intercooler the interest in water injection disappeared, but today, water injection is also of interest because it can potentially decrease nitrogen oxide (NOx) emissions in exhaust. Water injection is primarily used with piston-powered internal combustion engines, but it has also seen use with turbines.
The initial injection of water cools the fuel-air mixture somewhat, which increases its density and hence the amount of mixture that enters the cylinder. But the greater effect comes later during combustion when the water takes in significant amounts of heat energy as it converts from liquid to gas (steam), increasing piston pressure (torque) and reducing the peak temperature with its resultant NOx formation as well as the amount of energy absorbed into the cylinder walls. The duration of combustion is said to be longer. An interesting side effect that has been reported by some is that water injection effectively "steam cleans" the engine interior, resulting in less carbon residue buildup. Glowing hot carbon deposits are a known cause of knocking.
Fuel economy can be improved with water injection, although the effect on most engines with no other modification, like leaning out the mixture, appears to be rather limited or even negligible in some cases.
Some degree of control over the water injection is important. It needs to be injected only when the engine is heavily loaded and the throttle is wide open; as with other systems which need to monitor engine load, this can be determined by manifold vacuum, which is low when the engine is loaded and high when it is unloaded; however, provision must be made for starting, when the manifold vacuum is also low but water injection is undesirable.
Reports of more rapid corrosion of the steel and cast iron components of engines to which water injection has been added suggest that more frequent oil changes, particularly when the engine does not experience sustained high temperature operation to evaporate any water from the oil, are prudent.
- Jun 2007
- 207
July 29th, 2007 07:57 AM #2717* lan 21..
thanks for the explanation so that our turbo diesel bros may know how the system works...
but as for the corrosion inside the engine..it is only due to non controlled injections used by backyard installers of the past.. now that the system has been perfected and evaluated from its effects inside the engine..corroision is the thing of the past and frequent oil change..
the system we are using and has been testing has its own boost sensor and required metered jets to properly injects the mixture..it does not inject when theres no boost the sensor simply learns when its the safest point to start injecting ..
the system has been tested in the usa for a very long time and they have found out that it does not only steam cleans the engine but it prolongs the oil change resulting in cleaner oil..also as i have talk to their technician concerning corrosion ..its no where to be found inside their 200k plus kilometer reading trucks engine when they opened it up,as with their experience they found no problems in their engine even the enternals..the porpose of their opening up the engine is to check the effects of water/meth injection after years of use on a test engine..
in my experience ive tested it on diffrent turbo diesels, yuo can really feel the power it produces..only time the system is not to be used is on engines thats been drinking oil or blow by...
July 30th, 2007 01:27 AM #2718
Hi, im just new in this thread... possible ba ung CAI sa dmax?? anybody have pictures and comments?? ano din pala gamit ng breather??
July 30th, 2007 07:06 AM #2719
July 30th, 2007 10:00 PM #2720
cold air intake? then you have to remove the airfilter box assembly and replace it with a hifh flow filter routed outside the engine bay, commonly placed at the space inside the lower front bumper. delikads nga lang if nabaha. hihigop ng tubig yan..
why not the drop-in type K&N filter. just replace the stock air filter. CAI din ang principle nito..
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
