Results 31 to 40 of 250
November 14th, 2005 04:39 PM #31
Originally Posted by mrpink
Signature
November 14th, 2005 04:43 PM #32
Originally Posted by Boy Torotot
November 14th, 2005 09:49 PM #33
Originally Posted by bm5er
Tsikot Member Rank 2
- Feb 2004
- 448
November 14th, 2005 10:58 PM #35
pwde ba lagyan ng switch kung kelan mo lang kailangan sa ka mo sya switch ganon kasi yun honda ng bayaw ko 3 different sound acurate yun beep nya pag 6 inches na lang layo mo sa wall. ano kaya brand yun ok dito sa pinas for front and back sensor. thanks
November 14th, 2005 11:19 PM #36
nakita ko na problema ng backup sensor ko. it's the floor of our driveway. nung tinakpan ko yung driveway ng carton, yung part na malapit sa sensor, nawala yung beep. pebbles kasi yung flooring, kapag nasa concrete road na, ok na. bakit kaya?
Signature
November 15th, 2005 12:50 PM #37
Ganuun ba? I was about to suggest that maybe your sensors were loose (mine were on previous car, so it would beep on inclines)...
Masyadong reflective siguro yung pebbles. Because the sensor sends out an IR signal which merely ricochets off the road at an angle, while pebbles would reflect it straight back at the sensor. Strange na napaka-wide yung IR signal niya... try it kaya with aluminum cans and see if that triggers it, too? Does it beep for parking kerbs?
November 15th, 2005 12:57 PM #38
feeling ko sobrang sensitive ng mga sensors. masyado ng erratic yung binibigay na signal. is there a way na mai-adjust ang sensitivity ng mga sensors?
Signature
November 15th, 2005 01:19 PM #39
if i was in that same situation, my sensors would say 'object in blind area' as it always say if there is an obstruction way below the sensor
November 15th, 2005 01:43 PM #40
back-up sensors are helpful device. But again, they are there to assist in backing up. For SUV owners, it's not so accurate specially if you have a tire cover, because the cover is farther away from the bumper.
Coolant...
