Results 141 to 150 of 5910
May 16th, 2005 12:13 AM #141
zechs: Got mine for around 2300 +- , but its worth it. Its the Cali Duster / WaterBlade set.
May 16th, 2005 08:21 AM #143
Zechs: I applied the cleaner wax in a circular motion. It was easy to wax on and wax off. The results were ok (not great) but it really helped removing the dried up scratchX. My car is petrol red.
ILD and Dehadista: I've been reading good things about the caliduster and water blade. I'll look to get a set of my own! Too bad I also heard its very hard to find.
Btw, its wierd since the scratchX instructions said to let it dry before wiping off.. Will wipe off quickly in future uses. I think this also applies to glazes and polishers right? Wipe off quickly or it becomes very hard to remove...
Also, would using the Show Car Liquid wax after the IHS not so good? Is it because my paint is relatively new?
Thanks again guys!
May 16th, 2005 09:15 AM #144
Work the product in...
2) ScratchX is not a wipe-on, wipe-off product, (WOWO), it's more of a wipe on, work in product, (WOWI). You need to apply with a clean foam applicator pad and work the product in with a little passion.
The trick is to work the product in until it just begins to disappear and to apply more than one application. You see, the ScratchX, like all Meguiar's Paint Cleaners, contain a diminishing abrasive, as you work ScratchX in, the microscopic diminishing abrasives gently abrade the surface removing small particles of paint. But as you work it in, these diminishing abrasives breakdown. Thus, they quit abrading the finish and actually polish the finish to a clear, high gloss. This diminishing action turned polishing action is a benefit to you because it enable you to work out defects without leaving scratches behind.
Because the diminishing abrasive breakdown, you need to re-apply and repeat the process until the defects are removed.
- 290
May 16th, 2005 06:15 PM #146Originally Posted by theveed
btw. i currently have zymol cleaner wax (from US), cali car duster (from US din) and a couple of microtex mf. daily ko nililinis itong vios dahil daily na ang ulan dito sa cavite and applied a cleaner wax on the hood, trunk, and lh fender na, is it good for the meantime habang wala pa akong supplies ng wax? what product would you recommend for the moment? meron kasi kaming engineer ngayon na nasa US and i'm planning na magpabili ng either klasse or zaino but can't decide which one to get for my blaze red vios. help naman what to get if it's klasse i hope available pa dyan sa inyo para di na ako magpabili. hope to hear from you soon. i'll try calling you on your shop tomorrow.
anyway, i'm planning of bringing over my corolla one day sa shop nyo. napabayaan ko ng husto itong rolla.
May 16th, 2005 06:21 PM #147
IMO (my taste), Zaino and dark red doesn't really belong, it subdues the hue too much for my taste, but if you can buy Zaino Z2 Pro, then it'll be good.
The prob with Z is that if you dont use the Z shampoo and QD, it's a lot harder to maintain that shine, that's why Klasse is preferred since it's much easier to maintain using regular shampoo.
Your currrent maintenance is fine, just finish the product, I don't like Zymol's cleaner wax that much.
- 290
- 290
May 16th, 2005 06:46 PM #149looks like klasse wins and that's what i'm thinking also after reading a few reviews on it. thanks for the quick reply. it really helps since i don't know which of the two perfectly fits blaze red.
how much ba if i get klasse from your shop? kung wala na magpaorder talaga ako sa US.
nabili ko actually yang zymol cleaner wax 3 years ago and halted using it after getting megs yellow wax na pinaghati-hatian namin magkakaopisina. safe pa kaya itong cleaner wax 3 years old na? it still looks ok pero parang may buo buo na.
May 16th, 2005 11:12 PM #150
theveed,
do you have stocks of your citrus car shampoo? how much for the gallon? and if zymol cleaner wax is not so good, what other cleaner wax can i go for? meguiars na ba? im looking for a not so much expensive one sana..
Means "Sedan" in japan... Sakanila yung civic na 1997 may ferio sa ilalim nang civic na logo at...
Civic horsepower
