Page 255 of 256 FirstFirst ... 155205245251252253254255256 LastLast
Results 2,541 to 2,550 of 2560
    Apr 2024
    #2541
    Servo still gamet ko kapag idle ko 1.8rpmi then nag hung 1.3rpmi saan ko pwede adjust para instead sa 1.8vrpmi sa 1.5 rpmi nlang then sa 1k nlang sya mag hung, pwede ba sa fix sas papano left or right? Sana may maka pag share
    Jun 2011
    #2542
    Kung bago na ang throttle body at servo motor,
    ang next suggestion i check sa YT search ay.
    1. Fuel filter kung barado
    2. PCV valve or hose
    3. Vaccum hose na may leak, gaya sa brake booster
    Apr 2024
    #2543
    Quote Originally Posted by bxr monkey View Post
    Fuel filter done ,pcv okay pa may alog pa , pano po ba pag hanap Ng vacuum leaks
    #2544
    Quote Originally Posted by Rjmar View Post
    Kanina result Ng nag settled sa 900 nag turn ako Naircon nag dropped Minsan umaangat sir pero kapag nag accelerate dunadrop pa din
    sounds like a defective idle-up system.
    and by your cuento, mukhang intermittent yung defect.
    and the problem persisted even when you replaced the servo? hmmm....
    i read before, that some car owners simply bypassed the servo by installing a mechanical actuator...
    i read somewhere, that some altises have an unusually high idling rpm when started cold. they traced the problem to a leak in the intake manifold gasket.
    Apr 2024
    #2545
    Quote Originally Posted by tsarcolegrey View Post
    [size=15]Wala lang, gusto ko lang malaman kung marami may itlog dito sa forum! :D [/size]
    i'm an itlog owner myself, lancer 1993 egglxi, manhattan gray! :D
    Ako Meron din , ask ko lang din kapag may singaw ang bizscrew matatawag na ba natin vacuum leaks
    #2546
    yes, i think you're partially right.
    the biss screw (base idle set screw; google, natch!) is essentially a bleeder screw, that allows some air to bleed into the intake circuit. it naturally has a singaw,
    but it is a controlled vacuum leak.
    Oct 2024
    #2547
    Hello po, bago pa po ako dito. May binili akong lancer 96 in good condition pa, pero normal po ba yung steering wheel na mahirap paikutin if naka steady lang yung sasakyan? but if the car is moving na kahit mabagal lang, madali lang ito paikutin. Is there power steering in this car or wala? Oh baka sira lang yung power steering niya. Thank you!
    Feb 2024
    #2548
    Quote Originally Posted by Ianakoak View Post
    Check power steering fluid level and tire inflation.
    #2549
    yes and no.
    the lancer of that era came with pawis steering or with power steering, depending on the variant.
    based on your story, your car probably does not have power steering.
    motortrend is right. look for it, po, if you have one. in those days kasi, most PS were hydraulic and had PS fluid.
    google if you do not know what it looks like.
    #2550
    What variant? Power steering is available (stock) on the GLi and GLXi only. Check yours. Its also possible na mababa PS fluid level or dumudulas yung PS pump belt kaya malambot lang kapag tumatakbo/ginagasan.
