Results 2,341 to 2,350 of 2560
- Jun 2008
- 1,741
October 29th, 2015 08:53 PM #2341
- Mar 2013
- 20
October 30th, 2015 03:11 PM #2342
- Nov 2015
- 2
November 4th, 2015 08:25 PM #2343Mga Sir,
Meron po ba kayo recommended shop/mechanic sa Cavite around Imus or Bacoor area? May white smoke kasi sa exhaust ng eggy ko eh, and sabi ng mga napagtanungan ko at research, top overhaul na daw. Nauubos ung langis nya, pero wala naman leak sa ilalim, pero merong leak na galing sa Oil Cap.
Sana po meron kayo ma-recommend na mechanic.
Thanks!
- Nov 2015
- 2
November 4th, 2015 08:25 PM #2344Mga Sir,
Thanks!
- Nov 2015
- 13
November 7th, 2015 06:56 PM #2345Mga sir tanong ko lang.. ayaw po mag start ng lancer glxi matic ko. Cranking sya.. Battery is new, Fuel pump bago din. ano kaya reason? Thanks
November 9th, 2015 08:53 AM #2346
probably electrical related.
have you checked each of the high tension wires kung may lumalabas na kuryente?
kung wala, it could either be the HT wires or the distributor.
kung walang problema on both, it could be the ignition coil.
November 9th, 2015 08:54 AM #2347
kung makakabyahe ka pa ng onti, meron sa las pinas, mitsuprime..... pamplona going to SM southmall, bago sya mag manuela... from zapote nasa left side sya.. katabi halos ng LA Cars.
- Sep 2015
- 7
November 9th, 2015 05:42 PM #2348Bumili ako ng alternator. 3.5k nagpalit ako sa EL ko, magtatagal kaya to? Gaano usually ang buhay ng alternator?
November 9th, 2015 06:00 PM #2349
- Nov 2015
- 13
November 9th, 2015 09:00 PM #2350
Coolant...
