Results 391 to 400 of 415
- Apr 2015
- 376
April 15th, 2015 10:55 PM #391Iwan ko lang kung na post na ito dito.
Tipid tips.
Wag tatangalan ng yelo ang frezer ng ref. then make sure na laging may laman ang ref. Kasi pag walang makapitan ng lamig sa loob ng ref e pag bukas mo e labas yan lahat. Takbo nanaman ang ref mo. Kuryente nanaman yan.
April 16th, 2015 09:12 AM #393
As you may know short cut text messages are not allowed in this forum as well as barok sentence. With all due respect if you can't express clearly in Tagalog you may say it either Bisaya, Ilonggo, english or whatever dialects you're comfortable. besides your tipid tip does not make any sense at all. again, with all due respect. pls explain it to me your tipid tip like I'm a 5 yrs old child? pwede!
+101 here. di ko rin ma-gets ang ibig sabihin ni philsat. at saka pwede bang tumakbo nanaman ang ref mo? kahit ba sabihin nya na literal meaning yang sentence eh di pa rin mai-translate sa figuratively words/sentence noh
April 16th, 2015 09:19 AM #394
Baka suggest din ni philsat.....Bumili ng mga appliances direct sa planta, para makatipid, mas mura. Ha-ha!
Nakaka-aliw itong si philsat.
Masilip nga yung ref namin kung may laman. Alam ko puro tubig e. :DLast edited by chua_riwap; April 16th, 2015 at 09:23 AM.
April 16th, 2015 09:39 AM #395
haha. wait ako nga din.check ko lang ang laman ng ref namin. na intriga tuloy ako sa tipid tip ni philsat.
sa planta ba kamo bumili? kapag nakabili na sya sa planta, pwede nya rin i suggest na dun sa planta i plug in ang ref socket tapos bili ng extension cord hanggang umabot sa bahay nya. yan talaga ang masasabing tipid tip...
April 16th, 2015 09:39 AM #396
I also don't get the idea why would this unplugging a call of concern on electricity savings. It's only the small electronic sensor which is working such that when turned ON via remote, it adapt to the command. If that sensor consume any , it's only by cents, not a major consumption. On electric fans naman, though mechanical ang switch the circuit is not close so there won't be any electricity running thereby no consumption.
April 16th, 2015 10:26 AM #397
Philsat may be annoying with his penchant for using too much letter "i"s but his tip about freezers is actually valid.
Keep your fridge and freezer filled - bottles of tap water can fill empty space in the fridge, and you can fill empty space in the freezer with screwed up newspaper. Otherwise you're just cooling down air and making your fridge work much harder.
April 16th, 2015 10:35 AM #398
partly agree here, the current pass through in electric fan motor is totally cut off once the manual switch off button is pressed. But there are still some appliances consume a bit electricity in stand by mode. example stereo amplifiers etc.. or some appliances that produce heat at the back or bottom of the unit itself in stand by mode, it does a bit only
April 16th, 2015 10:37 AM #399
The advice is to unplug or turn off devices that are in standby mode. Newer devices consume less power now but before they used to consume more than 1W.
Standby power loss is quite significant.
April 16th, 2015 10:37 AM #400
May nagpost dati regarding sa ertiga hybrid. Parang parehas ata silang mild hybrid eh. Initially...
Geely Okavango
