Results 1,691 to 1,700 of 3483
- Mar 2008
- 54,247
August 12th, 2014 12:12 AM #1691
- Oct 2008
- 89
August 12th, 2014 09:23 AM #1692
August 12th, 2014 09:43 PM #1693
ok na guys nakakuha na ako ng kopya ng PMS sa casa ng friend ko
thanks sa help ^__^
- Aug 2014
- 25
August 15th, 2014 12:50 AM #1694Mga sir, ask ko lang po, planning to buy Fortuner, choice naming is 2.5 G, kasi pang everyday use tlga xia, kaya lang , sabi sabi, mas tumatagal daw ung gas engine. and also, magastos daw maintenance ng diesel compare sa gas engine. anu anu ba ginagawa sa maintenance ng diesel na di ginagawa sa gas. ask ko lang opinion nio.. thank you..
- Aug 2014
- 2
August 15th, 2014 10:29 AM #1695Sir, I bought a 2008 fortuner. ... its missing its jack and tools set, can anybody suggest where to get a set aside from the casa? Thanks!
August 15th, 2014 10:52 AM #1696
Auto supply should have them like the
*tire wrench (you need to find out the bolt size installed on the wheel). Notice it has that hole in the middle? You will need to attach the red hook (and extension) to the hole inorder to lower spare tire.
*red hook. this is need to lower the spare tire. just measure the length needed and make sure it fits inside the cut out hole in the rear bumper.
*jack (hydraulic type)
*hand tools - flat and philips screwdriver , pliers, etc (you can add as needed other tools you need)
- Aug 2014
- 2
- Apr 2013
- 43
August 19th, 2014 05:15 PM #1698selling my slightly used Racechip Pro2 for fortuner 3.0 liter
Rfs,upgrade to SF3/ 09173091666
- Apr 2013
- 43
August 21st, 2014 05:57 PM #1699
- Aug 2014
- 3
August 21st, 2014 06:29 PM #1700Mga sir, ask ko lang ano ba talaga ang recommended psi ng tires ng Fortuner 2.5G AT 2014?Nalilito nako kasi sabi ng SA ko 38 daw, but in toyota otis website it says 30psi. Nagbackread ako some of the members here keep it at 29-31. Yung SA ko ba yung nagkamali ng info? Please help! TIA!
Recently revealed at MIAS, this is the Changan Nevo Q05. Slightly smaller than a BYD Sealion 6...
Changan Nevo Q05 - PHEV Crossover for 1.2M
