Results 1,711 to 1,720 of 2561
November 26th, 2012 01:48 AM #1711
November 26th, 2012 09:42 AM #1712
The Lancer that came out between 93-96 only had 3 engine types. The EL had a 1.3 engine with no injection, the GLi had a 1.5 engine that had electronic injection and the GLXi had a 1.6 engine that was injected. What is your engine's displacement? The EL also had no built-in tachometre.
You need to change your oil every 5,000 kms.
As you bought your unit used, you need to have a mechanic check the belt, spark plugs, brakes and other consumables as to what condition they are in.
A way to make it more fuel efficient is to not let the RPM go past 2,000 and to keep your air pressure at 30-32.
Your dash lights can easily be changed. Just take it to Banawe. The shops there can change your bulbs.
Have the mechanic check your suspension and tighten your body bolts to identify where all the noise is coming from.
- Feb 2012
- 11
December 6th, 2012 02:42 AM #1713
- Nov 2012
- 16
- Jul 2010
- 570
December 7th, 2012 07:07 PM #1715Ilan years na battery mo. Baka mahina at kailangan ng palitan. Pa check mo na lang battery Minsan ay loose connection ng battery terminal cause niyan. Lihain mo mga battery terminal. Check na rin yun malaking wire galing - ng battery or ground wire baka puro kalawang na kinabitan nito sa kaha ng kotse.
- Jul 2010
- 570
December 7th, 2012 07:16 PM #1716Lahat ng gulong ng kotse ay may wheel bearing. Kapag luma na ang kotse or madalas malubog sa baha ay nasisira ang bearing at hirap na umikoit. Marinig mo na maugong ito sa area ng gulong. Takaw sa gas pag sira ang bearing na para ka kasi naka partial handbrake niyan.
Para malaman kung sira wheel bearing ay iaangat ang kotse at ibaba ang handbrake. Isa isa ikutin ang mga gulong. Dapat ay magaan at walang kalog ang gulong.
Sa Lancer ay buong wheel hub pag sa likod ang sira. Dahil hirap baklasin ang bearing nito. Yun sa harap ay pwedeng bearing lang ang palitan.
- Dec 2010
- 23
December 7th, 2012 10:15 PM #1717panung nabutas sir? panu nangyari yun? malaki ba damage? sensya na po kasi ganito din situation ng lancer ko same ng kay sir zeinrouke. di na gumagana speedometer mukhang worn out na yung sa loob ng transmission, pero di ko lang sure kung nakain din ng transmission yung gear o baka andun padin worn out lang talaga.
And mga magkano po kaya kung bibili ng power window switch yung buong set, kc converted lang yun sa driver side, pang RHD yung nakalagay sakin.yung sa likod naman nagloloose, gumagana minsan, minsan hindi. Please help! Thanks!
December 9th, 2012 09:13 PM #1718
Ay salamat nakita at nakapasok na ako dito, tiyak na makakatulong ang thread na ito sa pangangailangan ko sa binili kong Lancer Itlog 95 na sa umpisa lang marami at malaki na ang nagastos ko sa spare parts, accessories at repair sa sunod sunod na problema. Sa ngayon mayron problema ang lumitaw na hindi ko pa nadala sa mechanics kasi iipon pa ako ng budget for purchases and labor cost.
December 9th, 2012 10:08 PM #1719
dati unang malaking problema sa lancer el carbo type kong ito na hindi namin na solve ka agad agad ay ang ignition coil, fuel pump at fuel filter ng pinalitan namin ito ng bago OK po ang sasakyan, malakas, mabilis at medyo na bawasan po ang hatak sa gas consume nito.
Kahapon while driving at long distance travel with a speed of 100-130 kph travel around 100 kilos ng makarating na kami malapit sa hometown namin napansin ko po na humina ang makina at lumakas ang sounds nito na parang may piston break o backfire sound, dahil sa gabi po ang time na iyon walang available mechanics to check the car I forced this to drive it at home na naka speed gear 1 to 3 in the street highway at 20-30 kph speed, pag sa paakyat na road naka speed gear 1 to 2 lang ang kaya hanggang at 20 kph speed, sa ngayon hindi na nag start o nag start ang engine pero mahina maski gear 1 hindi kaya tumakbo.
I check the spark plug at tension wire kong mayron sira wala naman po akong napansin at ang sabi ng brother ko palitan ng new spark flug, pinalitan naman ganon parin nag start pero sandali naman namamatay. Hindi ko pa ito napa check sa mechanics kasi naubosan talaga ako ng budget for spare parts purchase o labor cost.
Any experience, good idea or remedy for this kind of problem, thank you po? Worried po ako na baka sira ang party ng piston ring or any parts inside, yari naman po ang bulsa.....kong malaki naman ang pang repair dito.
December 9th, 2012 10:52 PM #1720
Actually, nabili ko po ito gawa ng na akit po ako nito sa new paint, new rim/mags 17 basta maganda talaga, kaso few days of drive test the under chasis parts halos sira lahat, coil spring, shock, bushing, etc. ngayon halos bago, newly kinabitan ko pa ito ng original evo 3 body kit at spoiler purchase at NetPlay Racing, at ang dinidiin ko ngayon baka sa pag set up ko sa kanya na naka simota intake filter, high tension wire, etc. dahil sa nagbago at malakas tumakbo at high speed ako during driving baka ito na over used or driving ang sanhi nya kaya nagka problema sya ng ganon.
rack and pinion repair
