Results 1,451 to 1,460 of 1770
- May 2009
- 119
June 1st, 2010 09:16 AM #1451hello fellow tsikoteers, been at Izusu Batangas to check if they have cylinder compression test on their services. I approach the service advisor on the front desk and ask "meron ba kayo dito inoofer na compression testing?" sabi nung service ad "ano yun" sabi ko naman" "cylinder compression test para malaman kung nasa specs pa ang pressure inside each cylinder" sabi nung SA "wala kami nun sir bale sa takbo lang namin tinitingnan kung ioverhaul ang makina" medyo napangiti ako sabi ko sige thanks na lang. Can you name some shop that I can have a cylinder compression test?Wala kaya talaga dun or hindi lang alam nung SA na napagtanungan ko?Medyo gala kasi xwind ko eh malapit ng mag 200K ang odo pero ok naman pa naman hindi nagbabawas ng langis medyo nagiging sluggish lang kaya for peace of mind gusto ko magpacompression test. Thank you
- May 2009
- 119
June 1st, 2010 09:17 AM #1452
June 1st, 2010 09:18 PM #1456
- Oct 2007
- 50
June 1st, 2010 10:43 PM #1457
- Oct 2007
- 50
June 1st, 2010 10:43 PM #1458
- Mar 2008
- 3
June 2nd, 2010 03:59 PM #1459Goodafternoon mga Crosswind Gurus
First time user po ako ng Crosswind (Company Vehicle), am using a 2001 Crosswind XTO
I have few questions baka matulungan nyo po ako.
1. Yung steering wheel ko po masyado ng malaki ang play, anu po ba ito? Binasa ko po ang buong thread, may kinalaman po ba dito ang Centerlink and Torsion Bar?
2. Pinasilip ko po sa servitek and mukhang kailangan ko ng palitan ang mga tie rod (pwede bang gumamit ng 555) kaso may isa pang nasilip yung pinaka shaft ng steering gearbox is baluktot, may nabibilhan po ng ng surplus nito?
3. Recently bumyahe ko ng laguna and napansin ko pong sobrang maalon, anu po ba ang mga dapat kong palitan o gawin para malessen ang ganito? Shocks (what type po), add stabilizer link etc...
4. The vehicle has already ran 98k, kailangan ko napo ba palitan ang Clutch Disc, Pressure Plate at Release Bearing...
5. Pwede po ba kayo magrecommend ng reputable shop to do the mechanical works if ever, am from Manila po (Intramuros to be exact).
- Mar 2008
- 3
June 2nd, 2010 04:00 PM #1460Goodafternoon mga Crosswind Gurus
same as you
Post New Thread
