Results 1,411 to 1,420 of 1770
May 18th, 2010 04:30 PM #1411
May 18th, 2010 04:34 PM #1412
thanks chief... sa loob po... pina-smoke ko na rin pero di kasama ang amber (stock yun).
yun di chief sabi utol ko... napa-check tuloy ako sa internet... hehehe... mukha tuloy ginaya ko... pero oks lang... daming nag-appreciate pero meron ding ayaw...
more power and safe driving to all...
May 18th, 2010 04:35 PM #1413
May 19th, 2010 05:12 AM #1414
meron daw LED na tail light ng crosswind check mo sa Jayson's nung minsan pumunta ako dun nabanggit sakin na mero daw silang LED version na pang crosswind/sportivo.
- Oct 2009
- 59
May 19th, 2010 09:05 PM #1415hello crosswind owners,
mga sir pwde ba mamanually fold ang sidemirror ngcrosswind xuvi 2004?
May 19th, 2010 10:12 PM #1416
May 20th, 2010 09:01 AM #1418
- May 2009
- 119
May 21st, 2010 09:38 AM #1419just to share my experience last saturday sa SLEX....it was around 1pm tirik na tirik ang araw I am together with my wife and kids and we plan to go to Makati but ended up going to ATC because of matinding trapik...imagine from Caltex before Susana heights we was there around 12:30PM naka exit ako ng filinvest 2:00PM na grabe ang tindi ng trapik tapos ang init sa labas kaya we decided na nga na ATC na lang kami pumunta...what happened to my xwind was this, naka-half ang thermo ng aircon ko e medyo mainit pa din kaya nilagay ko sa 3/4 setting after a while nakita ko yung temp gauge ko biglang nagfluctuate pataas, upon seeing this pinatay ko na agad yun aircon ko tapos bukas bintana, after doing that bumalik naman sa 1/2 mark although kung tingan mo sa dash eh mas mataas ng konti sa 1/2 mark ng temp...bale nangyari ito ng nakaidle and stuck sa trapik ang napansin ko sa engine ko ay mababa ang idling niya that time mga nsa 600rpm lang...what I did is revolution ko time after time para makacirculate yung tubig...btw I'm on 50/50 mixture sa coolant...my question is overheat na kaya yun?kasi bumalik naman sa 1/2 mark after kahit naka 1/2 yung thermo ng aircon....pauwi nung gabi walang problem..oil color black...radiator and reservior hindi nagbawas ng coolant...also nagtop-up na ako ng 1 tube ng silicon oil sa fan clutch ko newly replaced din ang water pump ko GMB ang brand..does yung mababang idling ang nagcause ng fluctuation ng higher temp?ang bilis ng pitik nung pointer ng temp ko within 2 second umakyat then bumalik sa 1/2?I hope you can shed a light on this...thanks...OT kaya pala trapik may nasunog near Uratex sa may Cupang kaya Usi-usi bypasser kaya trapik sobra nun....
- May 2010
- 6
May 21st, 2010 12:06 PM #1420jaz014, ano year model ng ride nyo? puwedeng reason kasi ng pagtaas ng temp gauge is may bara na sa radiator niyo. Every 20,000 km dapat pinapalitan ang coolant, baka hindi napalitan ng ganung frequency yung sa inyo..
When changing your ride's serpentine belt, is it a must to replace the tensioner too?
Drive belt engine
