Results 1,331 to 1,340 of 1770
April 21st, 2010 09:09 AM #1332
Partner, why would you need to get another estimate? Pagawa mo na agad paglabas ng LOA! IMHO, insurance SHOULD replace the lower bumper (black plastic), small overfender (attached to front bumper) and RH headlight. Yung fender "lalambingin" lang ng denter yan to pop out.
April 21st, 2010 10:15 AM #1333
April 21st, 2010 10:48 AM #1334
April 21st, 2010 10:52 AM #1335
April 21st, 2010 11:02 AM #1336
- Apr 2010
- 23
April 21st, 2010 12:04 PM #1338
Is your vehicle still under warranty? If yes, i would not suggest you to use other fluid/parts on your car and servicing than authorized by ISUZU.
If past warranty period, yes, you can use any diesel engine motor oil to as long as it is SAE 40 --- of the same SAE rating recommended by ISUZU.
- Apr 2010
- 23
April 22nd, 2010 02:06 AM #1340
[QUOTE=TholitzReloaded;1459373]Thanks Benz,
eto pala naging damage ng crosswind ko.
This damaged costs Php50,187.00.. halos malaglag ako sa upuan ko buti may comprehensive insurance ako pero kailangan ko parin magbayad ng 30% depreciation ng parts which is more or less 6k plus the participation fee of 3k.
Coolant...
