Results 371 to 380 of 1136
September 7th, 2009 11:46 AM #371
- Feb 2008
- 13
September 8th, 2009 10:54 AM #372mga paps update ko lang kayo... nawala na yung sinsabi ko na ingay sa harap.. pinaawa ko sa servitek... yun daw talaga sakit ng n16.. ang culprit yung slider pin.. yung iba nilalagyan lang ng grasa.. yung iba sinasapinan naman.. cost me 150 pesos... whew kala ko kung ano na sira...
September 8th, 2009 03:28 PM #373
- Feb 2008
- 13
September 10th, 2009 11:39 AM #374what do you mean bro ng fix?.. alin ginawa nila?... kung yun.. yung slider pin.. sa may brake sa harap... pag inalis mo yung gulong makikita mo sa likod ng brake ( kalimutan ko na tawag dun.. ) yung pinaglalagyan ng brake pad sa likod nun may 2 turnilyo sa may parang bushing na goma.. pag inalis mo turnilyo huhugutin mo yun.. pde nga DIY lang.. madali lang.. sinapinan ng ginupit na lata ng coke in can o pde din daw palibutan mo ng grease... sorry kalimutan ko tawag sa part na yun...
September 10th, 2009 12:15 PM #376
Sa Casa po ang tawag nila dun ay "shim" wherein nilalagyan ng insulation using a thin slab of tinfoil para di magkaroon ng excessive play ang slider pin ng brake calipers. Disadvantage? Pwedeng ma-stock up ang brakes mo with prolonged use at sisirain din nya yung rubber dun sa slider pin with constant friction at pwedeng makadagdag din sa pagstock up ng slider pin within the caliper assembly. Temporary remedy? Lubrication every 5,000 kms pero eventually kakalampag din ito. OR replace the slider pins with the new ones-yung wala nang rubber insulation,pero even this fails kasi di talaga match ang sukat nya with the assembly. Long term solution? Machine shop build-up ng caliper pins para i-customize ang diameter nya with the caliper itself. From my own experience ito but I had to learn it the hard way (been through numerous nissan shops from Nissan Gallery,Nissan Car inc,and three Casas in Central Luzon PLUS halos pinapalitan ko na lahat ng suspension parts including tie-rod, rack end,suspension arm,shock absorbers,shock mounting,all engine supports,at pati rack and pinion assembly - ang pinakamahal na pinalitan at 69k) before finallly realizing the solution. Now the car feels brand new na,dapat lang sa dami nung pinalitan di ba. lol
September 11th, 2009 05:06 AM #377
just want to update regarding the engine noise issues that i've been having.
a week ago, i decided to drain dry my gas and changed back from XCS to Xtra Unleaded with E10 of Petron. after a day, meron pa ring noise and foul smell. after 4 days, tahimik na ulet makina pero meron paring konting smell. as of kanina, tahimik pa ren, tapos nde na masyado ung smell sa exhaust pipe.
so i therefore conclude, ung high octane fuel ng XCS caused the louder engine noise and the foul smell sa exhaust.
i was planning to keep using the Xtra unleaded until i read the Petron petition to DoE regarding ethanol being harmful to engines...
hayz. back to XCS....
September 11th, 2009 09:55 AM #378
Sigurado ka bang sa gas ang dahilan ng foul smell sa exhaust pipe . Tungkol din sa engine noise mo. kelan ka ba huling nag palit ng spark plug o tune up ng sasakyan.
September 12th, 2009 06:59 AM #379
- Jan 2008
- 13
September 12th, 2009 11:01 PM #380alam niyo ba sir kung san meron grill na body color with black mesh sa center four nissan sentra gx 2008 model and kung how much po?
2021 Nissan Leaf
