Results 1 to 10 of 12
- May 2004
- 903
September 5th, 2009 01:03 PM #1Is there such a thing?
mahina kasi yung wifi namin pag nasa 3rd floor na. although nakaka connect naman pero mabagal... any suggestion aside from those big antenna that you attach sa mga router?
September 5th, 2009 02:43 PM #2
i bought a second router (cnet - P700 lang) and a 15m long LAN cable to extend the wifi coverage in our house.
September 5th, 2009 02:51 PM #3
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 10th, 2009 09:09 PM #4
October 7th, 2009 04:30 PM #5
nung bumili ako ng router may nakita ako linksys range plus yata yun.. pang extend ba ito ng signal? parang extension cord?
OT: kung may booster meron ba wifi blocker? other than passwords.. network magic kasama ng linksys ko kaya lang kelangan meron din ganun yung i-block ko
October 7th, 2009 05:22 PM #6
I replaced my cnet el cheapo router with a Linksys WRH54G. World's apart in terms of signal strength. Now the whole house (1st & 2nd floor) is a hotspot. Abot din yung signal sa garage and front yard.
October 7th, 2009 05:42 PM #7
"Range extender" definition might differ from brand to brand. Generally routers that are "N" enabled have longer ranges along with those with three antennas or antennas that are bigger (wider) or longer.
Another option for security is enabling the MAC number filtering. Each wifi device has it's unique MAC number (machine number). You can configure your router to let only the ones listed within the router to connect. The others which are unlisted will be automatically rejected.
October 7th, 2009 05:44 PM #8
October 7th, 2009 05:51 PM #9
Can you feel the difference of N routers if the receiving machine is not N signal supported yet?
October 7th, 2009 06:46 PM #10
Yes, meron akong range extender sa compund namin and it do work effectively! Dati di abot sa kabilang house namin pero when we installed a linksys range extender abot na kahit loob kwarto nung 2nd house.
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
