Results 31 to 40 of 138
October 6th, 2015 07:43 PM #31
WDS is a complicated set up that require in depth knowledge about radio wave propagation, wifi speed standards (A, B, G & N), wifi channeling (channels 1 to 11), wifi encryption (WEP, WPA), wifi band (2GHz & 5GHz) in order to successfully pair and get maximal network speed from this set up
Its easier to crimp ethernet cablesLast edited by kisshmet; October 6th, 2015 at 08:36 PM.
- Jul 2014
- 35
October 6th, 2015 11:38 PM #32I am not techie kaya i hope someone can help me out... Our old zyxel internet modem was replaced by a wireless router/modem by PLDT. However, the signal doesn't reach some areas in our house, so what i did was to connect another wifi router (tp-link with 2 antennas). Hindi ba naglalaban yung 2 wifi routers sa speed ng DSL? What would be a better set up? Thanks
October 7th, 2015 12:15 AM #33
October 7th, 2015 06:43 AM #34
Maybe you can use it as wifi repeater, or buy a wifi repeater.
There are wifi router that can be configured as repeater. Go to your old wifi admin page, you will see an option that selected is DHCP. Basically that's the mode of the wifi. Change it to bridge mode. This will make that old wifi router a repeater.
https://en.m.wikipedia.org/wiki/Wireless_repeater
How to Extend Your Wi-Fi Network With an Old RouterLast edited by BratPAQ; October 7th, 2015 at 06:55 AM.
October 7th, 2015 12:50 PM #35
I think there are other Netgear models that meet both having a WDS function and detachable antennas. I just needed something low to mid-range that handled Netflix and game (Steam, Origin, Uplay, GoG) downloads without hiccups.
My old D-Link 802.11N router satisfied those two requirements. But, Netflix spent a lot of time buffering when I was using it. Wife got tired of waiting.
October 7th, 2015 02:50 PM #36
^netgear router was interesting in the sense that it uses a FQDN (fully qualified domain name) to configure the router instead of the typical IP address
October 7th, 2015 02:56 PM #37
check first the wifi speed standard provided by PLDT. N is the fastest and A is the slowest
PLDT is your root wifi if its of the G standard then even if you bridge it with N access points your entire wifi set up will be limited by the root standard
if the extending wifi is connected via ethernet cable and you inadvertently set the 2 wifis to utilize the same channel (channel 1 - 11) then each wifi could interfere with one another. interference will definitely slow down wifi access speed
one good thing about wifi device with WDS functionality is that it has utility to scan the wifi channels nearby. just pick the channel not picked up by the utilityLast edited by kisshmet; October 7th, 2015 at 03:27 PM.
- Jul 2014
- 35
October 7th, 2015 03:22 PM #38Thanks for all the replies on my query. I didn't do anything with the wifi set up i.e channel, DHCP. After following the setting up instructions, i left it as is na. I will try your suggestions. Thanks
October 11th, 2015 08:43 PM #39
Netgear router exploit detected
Netgear router exploit detected - BBC News
- Jan 2008
- 4,726
October 14th, 2015 01:04 AM #40Need help. PLDT provided a modem wifi in 1. Problem is their wifi signal is weak. I bought a cdr king wifi with repeater function.
Easy setup. Now problem is, i can connect thru the repeater but there is no internet access when using a smartphone, but with my laptop, i can connect with the repeater with internet access. What s wrong with my setup? I also noticed that if you access the wifi admin page thru the repeater, the admin page of the main wifi is displayed while if i access the admin page whike connected to the main wifi, the repeater admin page is displayed. Thanks for the help
Wow. No brainer to get the totl turbo over the seltos sx 1.4 turbo that also costs around 300k plus...
2022 Hyundai Creta
