Some notes:
-The power supply has been moved outside the case. I am still waiting to see if I can purchase a micro-PS to replace the external PS.
-The CDRW/DVD combo drive will be relocated UNDER the VHS PC to give it a more cleaner look. To do this, I need to find some sort of filler material (black high density foam, etc).
-The processor fan does have clearance between it and the case, if just barely. I was choosing from two styles and I went with the red fan since it was less taller than the other.
-The motherboard sits on a foam sheet to help minimize pressure points under the motherboard.
.. kasya din pala.
