Results 11 to 18 of 18
- Feb 2010
- 3
February 12th, 2010 01:38 AM #12
- Feb 2010
- 3
February 12th, 2010 02:09 AM #13
February 12th, 2010 02:20 AM #14
The modification is simple enough. You open up the UPS and remove the original battery. With wires of the same gauge as the one used in the UPS, you extend the existing battery wires and connect them to a couple of battery clamps (for best connection). Then attach the clamps to your car battery.
Note: UPS devices use either 6 volt or 12 volt batteries. In this case, you want a UPS with a 12 volt battery.
Do note that recharging will take longer than normal. Also car batteries do not last very long if you drain too much power.
UPS devices also have a "beep" audio signal when it's operating in battery mode. You can disable this by simply removing the electronic speaker either by removing the soldering or by cutting one of the two connections to the speaker.
February 12th, 2010 02:24 AM #15
- Feb 2010
- 3
March 3rd, 2010 12:29 PM #18
Xiaomi E-Car
