Results 1 to 9 of 9
July 12th, 2010 03:59 PM #1
guys help, ung laptop ng gf ko dv2000 hindi ma detect ung dvd drive. it's running on vista. tinignan ko sa device manager pero wala don. hindi ko mahanap. no power pag pasok ng windows pero pag simula pa lang may power pa, nag oopen pa pag pinindot ko ung open. pero once na pumasok na ng windows wala na, pag pinindot ko ung open hindi na rin talaga nabukas. pano kaya to?
thanks.
July 12th, 2010 04:31 PM #2
malamang sira na yan. based on my experience, the cd/dvd drive will still open and close but it won't be detected. if you can't find an original repalcement part, there are external dvd drives.
http://www.rsun.com.ph/view_item.php?item=CDR449
July 12th, 2010 04:41 PM #3
meron sa CDRKING. P1650 lang.
http://www.cdrking.com/?mod=products...tid=89&main=89
Tsikot Member Rank 4
- 2,719
July 12th, 2010 05:03 PM #4baka marumi lang contacts nung drive ... ganyan din nangyari sa hp laptop ko (dv1000) ... removed the screws, pulled out drive, cleaned the contacts, problem fixed and never came back
- Apr 2009
- 137
July 12th, 2010 06:06 PM #5rule out first the possible causes.. it's either a hardware or a software cause..
try to check the disk management under computer management tool.. im thinking that the hardware has no assigned drive letter only.
July 12th, 2010 08:27 PM #6
sana naman hindi pa busted drive. hehe. wala pa pambili ngayon.
*kinyo, masubukan nga yan. tutal out of warranty na rin naman ung unit.
*akosiempoy, feeling ko software issue since bago pumasok ng windows may power pa siya(ie. nasa loob ng bios). will try to do ung sinabi mo. but if that's the issue dapat somehow may power pa rin siya diba? example pag binuksan ung open dapat bubukas pa rin siya.
thanks
July 19th, 2010 01:44 PM #7
Most probably, hindi sira yan. It's an issue with Vista (and Win7).
Was your SATA controller set to ACHI? Your OD is IDE?
Anyway, I just fix the registry manually for this but here's the automated version:
http://support.microsoft.com/gp/cd_dvd_drive_problems
Good luck
- Apr 2010
- 188
July 23rd, 2010 09:30 PM #9
*horsepower, thanks. masubukan nga yan. wala pa lang akong time para ayusin eh. hehe
*malinkelly, try ko muna dito baka ma resolve. pag no choice na talaga saka ko dalin sa store. or pag nabwisit ako since puro virus yung laptop nung huling nag scan ako eh baka ireformat ko na lang.
thanks.
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
