Results 1 to 9 of 9
- Feb 2008
- 903
January 4th, 2016 09:46 AM #1Pls help... I am confused with the USB ports (2.0 and 3.0) of my PC since some would not be responsive when I attach a USB devise... Is there a tool or hardware devise that could check whether a USB port in a PC is busted or not?
January 4th, 2016 10:43 AM #2
Is the problem specific to a single physical port, or do you have the same issue in all USB2.0 and/or USB3.0 ports on the same PC?
What USB device or devices are you trying to connect?
Have you tried other USB 2.0 or 3.0 cables?
What I have encountered is that a frequently-used USB port may get worn down to a point where the contacts no longer make a good connection. Usually, unplugging and reinserting the USB device solves it.
- Aug 2015
- 862
January 4th, 2016 11:28 AM #4
How old is the USB device? Some legacy usb hd drives dont work with win7
- Jul 2013
- 2,450
January 4th, 2016 12:43 PM #5I would use trial and error to determine if a USb slot is not working. But make sure your USb slots are enabled. Check it in the device manager as someone already said.
January 4th, 2016 02:33 PM #6
Use Windows Device Manager
In the "Device Manager" window, click the + (plus sign) next to Universal Serial Bus controllers. You will see a list of the USB ports installed on your computer.
◦If your USB port name contains "Universal Host", your port is version 1.1.
◦If the port name contains both "Universal Host" and "Enhanced Host", your port is version 2.0.
◦If the port name contains "USB 3.0", your port is version 3.0.
also in the device manager, you can see if the device is working perfectly or has errors.
- Oct 2009
- 2,271
January 4th, 2016 03:27 PM #7tutunog naman yan pag detected ung usb saka makikita mo sa right lower ng PC mo kung nag install ng maayos ang usb drive mo.
- Jul 2013
- 2,450
January 4th, 2016 05:12 PM #8
January 6th, 2016 01:11 AM #9
Some USB ports may look like they're not working because of corrupted drivers. A number of (front panel) USB ports on my kid's old Vista PC quit working after she repeatedly yanked out a USB device instead of properly ejecting it. Device Manager showed all USB ports were working. But, some simply won't open a USB device.
After I did an OS reinstall, the front USB ports worked again. The only way to really know which USB ports were bad was to plug in a USB device and see what happens.
Are they on track to surpass last year's sales?
Car Sales Data (2025)
