Results 1 to 9 of 9
    Is the problem specific to a single physical port, or do you have the same issue in all USB2.0 and/or USB3.0 ports on the same PC?
    What USB device or devices are you trying to connect?
    Have you tried other USB 2.0 or 3.0 cables?
    What I have encountered is that a frequently-used USB port may get worn down to a point where the contacts no longer make a good connection. Usually, unplugging and reinserting the USB device solves it.
    Use Windows Device Manager
    In the "Device Manager" window, click the + (plus sign) next to Universal Serial Bus controllers. You will see a list of the USB ports installed on your computer.
    ◦If your USB port name contains "Universal Host", your port is version 1.1.
    ◦If the port name contains both "Universal Host" and "Enhanced Host", your port is version 2.0.
    ◦If the port name contains "USB 3.0", your port is version 3.0.
    also in the device manager, you can see if the device is working perfectly or has errors.
    Oct 2009
    tutunog naman yan pag detected ung usb saka makikita mo sa right lower ng PC mo kung nag install ng maayos ang usb drive mo.
    Jul 2013
    Quote Originally Posted by 1D4LV View Post
    Ang alam ko pag blue yung loob, USB 3.0. Pag puti, older version. Tama ba?
Is there a tool or hardware devise that could check whether a USB port in a PC is bus
