Results 1 to 14 of 14
    Aug 2004
    Tech Support: "I need you to right-click on the Open Desktop."
    Customer: "Ok."
    Tech Support: "Did you get a pop-up menu?"
    Customer: "No."
    Tech Support: "Ok. Right click again. Do you see a pop-up menu?"
    Customer: "No."
    Tech Support: "Ok, sir. Can you tell me what you have done up until
    this point?"
    Customer: "Sure, you told me to write 'click' and I wrote 'click'."
    Customer: "I received the software update you sent, but I am still
    getting the same error message."
    Tech Support: "Did you install the update?"
    Customer: "No. Oh, am I supposed to install it to get it to work?"
    Customer: "I'm having trouble installing Microsoft Word."
    Tech Support: "Tell me what you've done."
    Customer: "I typed 'A:SETUP'."
    Tech Support: "Ma'am, remove the disk and tell me what it says."
    Customer: "It says '[PC manufacturer] Restore and Recovery disk'."
    Tech Support: "Insert the MS Word setup disk."
    Customer: "What?"
    Tech Support: "Did you buy MS word?"
    Customer: "No..."
    Customer: "Do I need a computer to use your software?"
    Tech Support: ?!%#$
    Tech Support: "Ok, in the bottom left hand side of the screen, can you
    see the 'OK' button displayed?"
    Customer: "Wow. How can you see my screen from there?"
    Tech Support: "What type of computer do you have?"
    Customer: "A white one."
    Tech Support: "Type 'A:' at the prompt."
    Customer: "How do you spell that?"
    Tech Support: "What's on your screen right now?"
    Customer: "A stuffed animal that my boyfriend got me at the grocery
    store."
    Tech Support: "What operating system are you running?"
    Customer: "Pentium."
    Customer: "You've got to fix my computer. I urgently need to print
    document, but the computer won't boot properly."
    Tech Support: "What does it say?"
    Customer: "Something about an error and non-system disk."
    Tech Support: "Look at your machine. Is there a floppy inside?"
    Customer: "No, but there's a sticker saying there's an Intel inside."
    Tech Support: "Just call us back if there's a problem. We're open 24
    hours."
    Customer: "Is that Eastern time?"
    Tech Support: "What does the screen say now?"
    Customer: "It says, 'Hit ENTER when ready'."
    Tech Support: "Well?"
    Customer: "How do I know when it's ready?"
    A plain computer illiterate guy rings tech support to report that his
    computer is faulty.
    Tech: What's the problem?
    User: There is smoke coming out of the power supply.
    Tech: You'll need a new power supply.
    User: No, I don't! I just need to change the startup files.
    Tech: Sir, the power supply is faulty. You'll need to replace it.
    User: No way! Someone told me that I just needed to change the startup
    and it will fix the problem! All I need is for you to tell me the command.
    10 minutes later, the User is still adamant that he is right. The tech
    is frustrated and fed up.
    Tech: Sorry, Sir. We don't normally tell our customers this, but there
    is an undocumented DOS command that will fix the problem.
    User: I knew it!
    Tech: Just add the line LOAD NOSMOKE.COM at the end of the CONFIG.SYS.
    Let me know how it goes.
    10 minutes later.
    User: It didn't work. The power supply is still smoking.
    Tech: Well, what version of DOS are you using?
    User: MS-DOS 6.22.
    Tech: That's your problem there. That version of DOS didn't come with
    NOSMOKE. Contact Microsoft and ask them for a patch that will give you
    the file.
    1 hour later.
    User: I need a new power supply.
    Tech: How did you come to that conclusion?
    User: Well, I rang Microsoft and told him about what you said, and he
    started asking questions about the make of power supply.
    Tech: Then what did he say?
    User: He told me that my power supply isn't compatible with NOSMOKE.
    Customer Care Officer: "I need a product identification no. right now
    and may I help u in finding it out?"
    Customer: "Sure"
    CCO: "Could u left click on start and find 'MyComputer'?"
    Customer: "I did left click but how the hell do I find your computer?"
    Feb 2004
    as a tech support, you need to have a lot of patience or else tatanda ka agad.
    Quote Originally Posted by butchokuy
    i agree...
    May 2004
    MORE.......TECHNICAL SUPPORT
    Customer: I'm trying to connect to the Internet with your CD, but it just doesn't work. What am I doing wrong?
    Tech support: OK, you've got the CD in the CD drive, right?
    Customer: Yeah....
    Tech support: And what sort of computer are you using?
    Customer: Computer? Oh no, I haven't got a computer. It's in the CD player
    and all I get is weird noises. Listen.....
    Tech support: Aaaarrrrgggghhhh!!!
    Customer: Hi, this is Celine. I can't get my diskette out.
    Tech support: Have you tried pushing the button?
    Customer: Yes, sure, it's really stuck.
    Tech support: That doesn't sound good; I'll make a note.
    Customer: No .. wait a minute... I hadn't inserted it yet... it's still on
    my desk... sorry....
    Tech support: Click on the 'my computer' icon on to the left of the screen.
    Customer: Your left or my left?
    Tech support: Good day. How may I help you?
    Male customer: Hello... I can't print.
    Tech support: Would you click on start for me and...
    Customer: Listen pal; don't start getting technical on me! I'm not Bill
    Gates, damn it!
    Customer: Hi, good afternoon, this is Martha, I can't print. Every time I
    try, it says 'Can't find printer'. I've even lifted the printer and placed
    it in front of the monitor, but the computer still says he can't find it...
    Customer: I have problems printing in red...
    Tech support: Do you have a color printer?
    Customer: Aaaah....................thank you.
    Customer: My keyboard is not working anymore.
    Tech support: Are you sure it's plugged into the computer?
    Customer: No. I can't get behind the computer.
    Tech support: Pick up your keyboard and walk 10 paces back.
    Customer: OK
    Tech support: Did the keyboard come with you?
    Customer: Yes
    Tech support: That means the keyboard is not plugged in. Is there another
    keyboard?
    Customer: Yes, there's another one here. Ah...that one does work!
    Tech support: Your password is the small letter a, as in apple, a capital
    letter V as in Victor, the number 7.
    Customer: Is that 7 in capital letters?
    Customer: I can't get on the internet.
    Tech support: Are you sure you used the right password?
    Customer: Yes, I'm sure. I saw my colleague do it.
    Tech support: Can you tell me what the password was?
    Customer: Five stars.
    Tech support: What antivirus program do you use?
    Customer: Netscape.
    Tech support: That's not an antivirus program.
    Customer: Oh, sorry...Internet Explorer.
    Customer: I have a huge problem. A friend has placed a screensaver on my computer, but every time I move the mouse, it disappears.
    Tech support: How may I help you?
    Customer: I'm writing my first e-mail.
    Tech support: OK, and what seems to be the problem?
    Customer: Well, I have the letter 'a' in the address, but how do I get the
    circle around it?
    A woman customer called the Canon help desk with a problem with her printer.
    Tech support: Are you running it under windows?
    Customer: "No, my desk is next to the door, but that is a good point. The
    man sitting in the cubicle next to me is under a window, and his printer
    is working fine."
    Hehe, funny.
    Feb 2005
    i sure do hope na loko loko lang yang mga jokes na yan kung totoo yan.. abaa... waaaaaaaaahh
    Jun 2004
    Haay, some of these really do happen. I work as a tech support and it can be a very difficult task sometimes...
    Dec 2003
    ...... thank you for calling......
    Customer: I’m having problems using my PC.
    Tech: Is your computer running right now?
    Customer: No, it’s standing still in front of me.
    Call at Trend Micro
    Customer: My computer has a virus.
    Tech: Do you have PCCillin in your computer?
    Customer: No, I’ll go check my medicine cabinet.
    Customer: I want to scroll back to the top of the screen but my mouse is malfunctioning.
    Tech: Try using the arrow keys.
    Customer: It takes really really long to go back to the top.
    Tech: How about the ‘Home’ key?
    Customer: It’s with my parents. I’ll just wait for them to come back to the house.
    Calls at Microsoft
    Customer: I have a licensed copy of Windows XP Home Edition and would like to ask something about the legality of its usage.
    Tech: Ok, what’s your question?
    Customer: Is it ok to install it in my office computer?
    Customer: Hi, I would like to avail of Windows XP from my laptop. Can you recommend the best version for me?
    Tech: We have Home Edition and Professional Edition.
    Customer: Do you have anything else? I’m not yet an expert in computers and usually not in my house.
    Customer: How much is a copy of Windows XP?
    Tech: 100 dollars.
    Customer: Does it come with a free doll of your penguin mascot?
    Tech: Hi, how can I help you?
    Customer: I cannot find the ‘script’ function.
    Tech: Sorry, I do not get you.
    Customer: This has to do with a Word document. I only see the ‘print’ function, but my document is actually written in script.
    Customer: I’m having trouble connecting my PS2 to my PC.
    Tech: Playstation 2 you mean?
    Customer: Yes.
    Tech: I’m afraid that really cannot be done.
    Customer: Are you sure? I checked the ports at the Control Panel and there is a ‘PS/2’ port indicated.
    Customer: I’m having trouble running many programs at the same time.
    Tech: How much is your memory?
    Customer: Sorry, I’m not quite good in remembering things.
    Customer: I’m having trouble using my speakers.
    Tech: Aren’t they malfunctioning.
    Customer: No, I just bought them yesterday and had them tested.
    Tech: Can you go to the hardware section?
    Customer: Ok, what will I buy there?
    Customer: My screen is fluctuating when I’m trying to watch a VCD.
    Tech: Maybe your monitor needs to be replaced already.
    Customer: No, it just worked fine in my friend’s PC yesterday.
    Tech: Maybe you need to get a new video card.
    Customer: Why? My membership at the video shop expires 6 months from now.
    Customer: I’m having problems installing my modem.
    Tech: Do you have a driver?
    Customer: No, I’m the one driving myself.
    those are too true to be jokes.
    i once had a customer who was wailing so hard due to a blue screen error.
    and a customer who was complaining, she said she bought a 40GB hard drive and she expected 40GB of free space.
    Feb 2005
    no kidding? those actually happen? whaaaaattt?
    kala ko yung iba mejo ok pa honest mistake for someone who's not familiar with computers. but yung iba mashadong over na eh. hhehe o well, wawa naman mga tech support hehehe
    Dec 2003
    at least those situations make the job less boring, laki naman sweldo e hehe
    kaya ayoko mag tech support e. hehehe.
    the best ung sa NOSMOKE! hahahaha
    Nagloloko tsikot kapag internet explorer gamit ko. Pero sa google ok naman.
    Example ng problem ay hindi ako makagawa ng separate lines, lahat sunod sunod kahit hindi ganun pagkaka-type ko.
    Also yung mga smiley hindi nagana sa advanced mode. Papano kaya ito?
    Note: Ayos na pala, delete browsing history lang ginawa ko ok na.
Tech Support
