Tech Support: "I need you to right-click on the Open Desktop."
Customer: "Ok."
Tech Support: "Did you get a pop-up menu?"
Customer: "No."
Tech Support: "Ok. Right click again. Do you see a pop-up menu?"
Customer: "No."
Tech Support: "Ok, sir. Can you tell me what you have done up until
this point?"
Customer: "Sure, you told me to write 'click' and I wrote 'click'."
Customer: "I received the software update you sent, but I am still
getting the same error message."
Tech Support: "Did you install the update?"
Customer: "No. Oh, am I supposed to install it to get it to work?"
Customer: "I'm having trouble installing Microsoft Word."
Tech Support: "Tell me what you've done."
Customer: "I typed 'A:SETUP'."
Tech Support: "Ma'am, remove the disk and tell me what it says."
Customer: "It says '[PC manufacturer] Restore and Recovery disk'."
Tech Support: "Insert the MS Word setup disk."
Customer: "What?"
Tech Support: "Did you buy MS word?"
Customer: "No..."
Tech Support: "Ok, in the bottom left hand side of the screen, can you
see the 'OK' button displayed?"
Customer: "Wow. How can you see my screen from there?"
Customer: "You've got to fix my computer. I urgently need to print
document, but the computer won't boot properly."
Tech Support: "What does it say?"
Customer: "Something about an error and non-system disk."
Tech Support: "Look at your machine. Is there a floppy inside?"
Customer: "No, but there's a sticker saying there's an Intel inside."
Tech Support: "What does the screen say now?"
Customer: "It says, 'Hit ENTER when ready'."
Tech Support: "Well?"
Customer: "How do I know when it's ready?"
A plain computer illiterate guy rings tech support to report that his
computer is faulty.
Tech: What's the problem?
User: There is smoke coming out of the power supply.
Tech: You'll need a new power supply.
User: No, I don't! I just need to change the startup files.
Tech: Sir, the power supply is faulty. You'll need to replace it.
User: No way! Someone told me that I just needed to change the startup
and it will fix the problem! All I need is for you to tell me the command.
10 minutes later, the User is still adamant that he is right. The tech
is frustrated and fed up.
Tech: Sorry, Sir. We don't normally tell our customers this, but there
is an undocumented DOS command that will fix the problem.
User: I knew it!
Tech: Just add the line LOAD NOSMOKE.COM at the end of the CONFIG.SYS.
Let me know how it goes.
10 minutes later.
User: It didn't work. The power supply is still smoking.
Tech: Well, what version of DOS are you using?
User: MS-DOS 6.22.
Tech: That's your problem there. That version of DOS didn't come with
NOSMOKE. Contact Microsoft and ask them for a patch that will give you
the file.
1 hour later.
User: I need a new power supply.
Tech: How did you come to that conclusion?
User: Well, I rang Microsoft and told him about what you said, and he
started asking questions about the make of power supply.
Tech: Then what did he say?
User: He told me that my power supply isn't compatible with NOSMOKE.
Customer Care Officer: "I need a product identification no. right now
and may I help u in finding it out?"
Customer: "Sure"
CCO: "Could u left click on start and find 'MyComputer'?"
Customer: "I did left click but how the hell do I find your computer?"
