Page 64 of 86 FirstFirst ... 145460616263646566676874 ... LastLast
Results 1,261 to 1,280 of 1705
    #1261
    Daikin costs almost 33-34k
    10k almost expensive kaysa sa Samsung
    But as per experience sa church namin.
    Yung Daikin pinka matibay
    Wala pa napalitan na compressor unlike sa Hitachis doon na floor mounted
    Sent from my SM-A507FN using Tapatalk
    Kahit kaibigan kong sa Samsung nagtatrabaho, hindi bilib sa Samsung aircon. [emoji28]
    Panasonic or Daikin pa rin talaga. LG pag lower budget.
    #1262
    pcb kasi nila sablay bro
    ang weird lang, kasi design flaw tapos tagal ng issue ay di parin na address. as early as 2014 pa yun unang case ko nabasa yan sa pinas e
    LG rin, design flaw na kahit naka unplug yun AC mo, nag generate parin motor pag umikot elesi while cleaning. ending fried board din. buti sana if lahat naglinis ng split type alam yan
    Sent from my RMX2020 using Tapatalk
    Apr 2012
    #1263
    My aircon was 2012 built.
    I don't know may issue pala na ganon
    Apr 2012
    #1264
    How about Carrier?
    LG is much better than Samsung ba?
    Jan 2008
    #1265
    How about Carrier?
    Mitsubishi/panasonic/daikin. Dyan ka na lang mamili
    Sent from my Redmi Note 8 Pro using Tapatalk
    Aug 2004
    #1266
    Check nyo rin ang add-ons. May base model and top of the line din kasi mga yan parang oto. If cooling lang kelangan mo then you won't need the nano-e mosquito killer whatever model of the same capacity that sells for a couple thousands more.
    Sent from my SM-A605G using Tapatalk
    #1267
    How about Carrier?
    i carrier/condura.
    local.
    parts are supposed to be more available, dahil local.
    sometimes, it's not the pagka-super-tibay. sometimes, it's just the availability of spare parts.
    Jun 2005
    #1268
    How about Carrier?
    Yung friend ko 3x na pinalitan ang main board ng carrier nya. Bigla na lang nasira.
    Im guessing baka nagka voltage spike sa kanila kaya nasusunog ang board
    Sent from my MI MAX 2 using Tapatalk
    #1269
    Quote Originally Posted by sirkosero View Post
    are these boards inside the building, protected from the elements by roof/ceiling and walls?
    or are they outside?
    Jan 2009
    #1270
    It's likely they're not properly grounded.
    All power supplies have built-in voltage suppression circuits.... it's the standard. However, these circuits only work when there's a path to ground to dissipate the energy. If there's none, this surge will look for the path of least resistance... going through fragile silicon transistors and ICs until it dissipates.
    #1271
    How can the DC fan motor damage the indoor board? - YouTube
    May 2019
    #1272
    Nice Sir Ninja.. Check ko nga kung nagse-service din sila ng treadmill.. Nakakabilib yung nasa video baka sya na ang sagot sa problema ko.. Nag-subscribe na ako.. Hehehe [emoji16][emoji41]
    #1273
    ...what is the current of that generated electricity?
    #1274
    more than enough to fry your board bro
    #1275
    buti nga yan mga yan nag share e
    other tech people dont
    Jun 2005
    #1276
    Main board doc, the one for the indoor unit.
    Jun 2005
    #1277
    Same assessment. Sa condo siya nakatira. Around 3 years pa lang yung building. Di ba standard ang grounding ng condo as part of building code(?)
    Sabi ko kuha na lang sya ng power on delay or bili siya bagong aircon hehe
    #1278
    What developer?
    Jan 2016
    #1279
    Ninja bro, true din ba yan for dual inverter window units ng LG?
    #1280
    yes bro
    sabi sakin nun naglinis nun LG dual inverter ng friend ko di daw alam ng ibang AC cleaner yun.
Split Type Aircon: Which is best?
