Page 167 of 169 FirstFirst ... 67117157163164165166167168169 LastLast
Results 1,661 to 1,670 of 1687
    #1661
    Is anyone here using Samsung Windfree airconditioner? ... How is it? ...
    Seems okay. Got it for a good deal at just P20K eh for the 1hp one. Effective yung windfree system lalo na if malapit ka sa AC. Kapag malamig na room, we activate it. Seems mas matipid nga kung ganun.
    Mar 2004
    #1662
    TCL ... Daikin ... split type inverter aircons ... can those who are using these brands give feedback ... Is the Daikin worth the price premium over TCL? ... Will the savings in electricity offset the price premium of Daikin over TCL? ...
    Open to suggestions from other brands ... 2.0 HP ... 24-25 square meter room ...
    Nov 2019
    #1663
    Daikin user here since 2022, satisfied naman ever since.
    Advantage ng Daikin na nagpadagdag ng saving is the human sensor.
    May auto detection siya na if walang tao sa loob ng room, mag fallback yung ambient temp setting niya by +2 deg.
    Tinanggal na ata to sa latest model nila due to cost cutting measure.
    For that sq.m room, I suggest to go for 2.5HP which is ideal for 20-35 sq.m.
    Mas mamaximize niya yung pagka inverter niya if ioversize mo yung unit over the area.
    That 2HP is for 15-25 sqm only if real world use ang usapan.
    As for savings, I have 2 Inverter ACs sa bahay, 1 is Windows Type and the other is 1.5HP Daikin Split.
    May Inverter Ref din ako.
    Monthly rate ko sa kurente is naglalaro sa 3k-3.5k ave, mahal electricity rate sa place ko compare sa Luzon area.
    Heavy ang usage nyan sa Daikin AC ko, parang 18-20 hrs ata ave usage namin sa Daikin AC.
    Also if malapit kayo sa ilog/putrid water, I suggest na pinturahan mo yung evaporator ng Anti-Rust.
    Yung sa left side, kakalawangin yang part na yan if malapit kayo sa area na yan.
    Mar 2004
    #1664
    3T bill for 18 hours use is crazy cheap ... Daikin King series still has that sensor ...
    Nov 2017
    #1665
    Quote Originally Posted by carxynogen View Post
    Makikisabay lang ng tanong, okay ba ung Carrier Aura na 2.5HP and Carrier/Midea-based Split types in general?
    On paper it looks like a derated 3.0 HP unit (25,500 kJ/h rated; 33K Max which seems to be close enough to what Midea(MSCE-25CRNF8 -25,320 Kj/H rated; 26,900 kJ/h(25,500 BTU/h) max) and Daikin (D-Smart Queen FTKC71AVA- 24K BTU/h(25,320kJ/h) rated; 24.5K BTU/h(25,850 kJ/h) max) rates their 3 HP units at.
    Nov 2019
    #1666
    Wierd yung forum reply ngayon. One liner lang yung input response editbox. Ayaw pa mag proceed dahil response is too short daw.
    Nov 2019
    #1667
    Quote Originally Posted by LOLZ View Post
    I am not a fan of Carrier brand actually, but my bad experience was from their window type.
    Sa circuit nila, may device dun na mag titrip on a certain ocassion ng overload use.
    Sa time na yun, palaging may low voltage sa area namin which in turn will switch our electricity on/off for 3 times.
    Hindi naman siya nagloko earlier sa instance na yun.
    It was during summer ata na medyo na overuse namin yung AC at nagloko na naman electricity supply namin (low voltage).
    After nun, hindi na mag ON ang AC kaya tumawag kami sa technician ng Carrier.
    Dun namin nalaman na may i switch lang sa loob ng circuit, tinanong namin yung technician paano yun galawin.
    Hindi i reveal, certified technician lang daw dapat gumagawa nun.
    Don't tell me everytime mangyari yun, tatawag tayo sa technician nila para lang i reset yung part na yun.
    #1668
    i think it's in youtube now.
    Nov 2017
    #1669
    I think may nabasa rin ako parang ganyan ang experience with their Inverter WT pero before pandemic pa kaya nagbabakasakali baka naayos na nila ung issue medyo nakakadismaya if until now ganyan parin lalo na if kelangan pa ng technician na baklasin un unit para mareset. medyo OT pero did you end up keeping ung carrier na WT ?
    #1670
    two of our carrier window types sprung leaks. prematurely, i opine.
    sabi ng third-party repairman, "kung ganyan ang kalidad ng carrier, kuha na lang kayo nang china brand. siguro naman ay kasing tagal ang buhay niya, nguni at mas mura naman".
    hmmm...
Split Type Aircon: Which is best?
